Tweeters fitted
- jabber
Tweeters fitted
Got hold of a pair of 4 series tweeters from ebay for a reasonable price and a nice easy job to fit and makes a huge difference to the sound
Z less again
Tweeters fitted
Do they fit directly into the blanks in the doors? Is the wiring there to plug into? Does anything need programming to make them work?
Can you tell I’m interested in doing similar?
Z4 S-Drive 35i
Audi TT S-line
Mazda MX5 Mk2.5 (for sale)
Wokingham Berkshire
Audi TT S-line
Wokingham Berkshire
- jabber
Tweeters fitted
They are a direct fit and they came with the wires which plug in to the main door speakers, no programming needed. If you look at realoem for the z4 tweeters it shows that they have been superseded and which other bmw,s they are fitted to
Z less again
- Tumnus
Tweeters fitted
Tweeters make a massive difference, I was contemplating getting an amp and the speakers replaced, but the tweeters made such a difference that I haven't bothered (I did change the mids as well though). Still not very loud though, but good enough, my hearing is shot enough already.
I bought and fitted the Rockford Fosgate replacement door speakers (mid and tweeter), these are a straight swap and require no coding.
CC retrofit, LUX 180 Angel Eyes, Rockford Fosgate Speakers, BMW Performance Grilles, LCI Indicators, Remus exhaust, SmartTOP
https://www.flickr.com/photos/nickj1972/albums
Online
Tweeters fitted
For info.......
OEM Tweeter is... 9220750 and readily available on eBay
Or if you have the Harman Kardon system then you need 9220751
Both sides are the same part number.
HTH
HTH
Dave
2011, 23i, Grey with Red leather.
- Dr-Jon
Tweeters fitted
I changed my door speakers out with Mini ones and added the mini tweeters at the same time. made a big difference.
and the Mini ones are a lot cheaper than the Z4 ones the door speakers were a straight swap the tweeters need to be dremeled to fit, the size is correct but the mini ones have 2 slots and the holder in the z4 had 3 slots, so dremeled an extra slot in the plastic speaker housing
only took about 10 minutes each.
Tweeters fitted
Would these fit into the E85 tooDr-Jon wrote: ↑Thu Nov 30, 2017 6:34 pm I changed my door speakers out with Mini ones and added the mini tweeters at the same time. made a big difference.
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
Tweeters fitted
Mrs used to have a Mini Coopers S convertible but I was never impressed with the sound of the stereo. What year was that from?
Z4 S-Drive 35i
Audi TT S-line
Wokingham Berkshire
Audi TT S-line
Wokingham Berkshire
- Dr-Jon
Tweeters fitted
not sure you would have to look realOEM to see. but the door speakers from a mini surprisingly are better quality than the ones i took out.firebobby wrote: ↑Thu Nov 30, 2017 7:20 pmWould these fit into the E85 tooDr-Jon wrote: ↑Thu Nov 30, 2017 6:34 pm I changed my door speakers out with Mini ones and added the mini tweeters at the same time. made a big difference.
Tweeters fitted
Don't forget the rear speakers also have space for tweeters.
Tweeters fitted
Rear speakers have an impeded/reduced signal from the fronts, unless you swap to using an amp with pre-outs any money you chuck on the rear speakers is basically a waste of time.
Just swap out the mids, footwell speakers and tweeters and you will have an awesome sounding setup. I power mine with a little blaupunkt amp, hertz speakers and focal tweeters. It's lovely and punchy, with deep bass and enough clarity to be heard well into very illegal speeds (apparently). If you need some staging then the crappy old rears can be faded in to give you a token gesture.
Price for all my stuff including fitting and sound deadening was £628
- Burple
Tweeters fitted
hey all.. possible stupid question, are there any guides out there on the forum for swapping speakers? did a quick search, but couldn't see anything..
Cheers!
Cheers!
Online
Tweeters fitted
Dave
- jabber
Tweeters fitted
Not sure why if its only the door tweeters it only took me 10 mins a side
Z less again
