Wondermike said:Nice difference![]()
Think they look fine as they are TBH.
davidmbell said:Did you trap something in the left side of your engine bay when you closed the bonnet? Looks to be raised slightly in picture 2?
Don't want it popping open or something being left there that shouldn't be?
KSY10 said:Hi All Pina,
Any chance you could show a picture of the box that your bulbs came in please so that i can compare them to mine. Your bulbs look much brighter and more prominent than mine. Perhaps i need a higher wattage?
David
PS the new lights look loads better!
All Pina said:KSY10 said:Hi All Pina,
Here are the ones I used @KSY10, note same power but slightly lower temp scale. I think you can only use bulbs rated 35w otherwise it will throw a faulty bulb message to OBC. Somebody else posted in another thread, the higher the colour temp (k value) the bluer the light but less in visible spectrum hence not as bright.
jward said:The mod looks great. Are they just as easy to fit as standard bulbs?
All Pina said:
Obsidian said:The change looks great. Nice clean white light.
I've seen a new 5 series with white angel eyes. Is this new for the 5? If so, has anyone approached their dealer about getting them to make the change with BMW bulbs?
davidmbell said:Don't forget that when you're comparing lights you have to establish you're comparing like for like settings, and that SIDE lights on a Z4 look very dim and yellow, compared to the Daylight Running Light setting. And even with new bulbs if you have them on 'sides' they can look rubbish.
Here's my MTECs, on DRL mode http://www.z4bmw.co.uk/lights/
David
