I'm back again with another problem with my beloved Z4. I've contemplated selling her and getting something else but I've decided to have one more crack at getting her right. If this turns out to be something really expensive then I'm going to have to move her on to someone else
So in the video below you can hear a whining in the background. I couldn't hear it when I played the video on my phone but when I played it through my Bluetooth speakers and turned it up, it's noticeable. Around 50 seconds into the video the whining is worst. The video might not do it justice but around the 50 second mark it's loud enough to be audible even with the air con blowing and some background music on.
This whining is noticeable at low speeds but is worse around 25-30mph (which is around the 50 seconds mark) If I go faster than 30 it starts to fade or maybe the engine/road noise masks it.
My observations so far...
I would expect a wheel bearing to cause a constant noise that would get louder as I speed up so I'm guessing it's not a faulty wheel bearing. From what I can gather after searching Google, it's probably a gearbox or diff related issue.
There are no other symptoms apart from the whining. The car feels perfectly fine and changes gear fine, accelerates fine, etc.
For your viewing pleasure....
https://youtu.be/1R99fnfRaeU
Has anyone experienced, heard or fixed an issue like this? I want to know what I'm dealing with and if I should expect a large bill :|
- It does it in gear
- It does it in neutral
- It does it when my foot is on the clutch
- It does it with my foot off the clutch
- It does not do it when the car is stood still
- It tends to be worse when the car has warmed up
