SpecialNick
So I've had my sDrive 23i (2010) for about 15 months and had no problems at all with it, however when I went to get the locking wheel nut adapter from the well in the boot (which contains battery and hydraulic pump for roof) I found it contained about an inch of water.
Obviously I cleared the water with plenty of kitchen roll, however a few days (and plenty of rain) later, it had filled up again with about an inch of water. I decided to try the roof and sadly it does not work, the side windows roll down and it tries to lift the rear window however gets about 1cm and then goes up and down until the warning chime comes on. It does close properly however.
So...
Firstly any ideas where the leak is coming from? The boot seals are fine and there's nowhere obvious where the water is getting in, a few posts seem to suggest the rear light cluster is the issue?
Secondly I'm hoping I can dry the various electrical terminals on the roof control unit and all will work ok...
Any comments/suggestions would be welcomed to prevent this in the future!
So...
