PVR has bullied me into buying an Intravee so as a result my Trusty IceLink Plus is for sale.
Installation is easy, remove the centre air vents, you can use the Petach method do do this if required. Then remove the Black Small plug from the multi block, slide the insert out of the plug and replace with the one on the Dension loom. Insert the Dension main multi plug between the car main loom and head unit. Feed the iPod lead through to the glove box (May need to remove glove box to make life easier). No need to drill any holes as there is already a gap you can use. Re assemble car and your good to go. If you have a CD changer you will have to disconnect it (two leads accessed from the boot).
I will post pictures of the kit if required, but it's all plug and play and easily fits behind the AC controls.
Features
5 Play lists using Stations 1-5 (Best to create play lists in iTunes called 1-5 so they sync correctly.
ID3 Tags (Displays Artist/Track Information.
Ability to select By Artist, Album, Genre etc.
I used this with a 3rd and 5th gen iPod with no problems. I am aware that Apple change there technology to prevent 3rd party products being so compatible so cannot guarantee newer one will work 100% (Classic onwards I believe)
I will include a CD with all the files I have and can also include a extra loom so that the kit can be used in a E46 3 series if required.
Looking for £75 delivered by Pay Pal gift or Bank Transfer.
If your local to me I'm more than willing to assist in fitting also.
Any questions drop me a PM.
Features
