X-S-Z said:Whats the pre-requirement for xenon for? Can aftermarket ballast not be used?
cj10jeeper said:X-S-Z said:Whats the pre-requirement for xenon for? Can aftermarket ballast not be used?
You will need the LCM reprogramming to recognise the Xenon Vs halogen. Without they will not function correctly.
They will also not fit post facelift as they are a different wiring configuration, but there is little value in doing that as they are already clear, even if not xenon.
X-S-Z said:cj10jeeper said:X-S-Z said:Whats the pre-requirement for xenon for? Can aftermarket ballast not be used?
Obviously I've been looking at aftermarket xenon... so what would the cost and implications be to fit these then? Its a pre-facelift car, 2004.
cj10jeeper said:Don't have a price but call your dealer (or local indy) and ask for the price to reprogramme your car to accept Xenon lights as a direct replacement for your halogen. They may or may not do the work depending if they are funny about retrofit without all the automatics we've talked about before. I know at least 1 forum member here did exactly this job at a local indy. Decide if you want to do the labour to fit them or add that to the quote. It will take you about 2 hours first time to remove the bumper cover, swap over the lights and refit.
They will of course need the beam aligning on completion
X-S-Z said:cj10jeeper said:Don't have a price but call your dealer (or local indy) and ask for the price to reprogramme your car to accept Xenon lights as a direct replacement for your halogen. They may or may not do the work depending if they are funny about retrofit without all the automatics we've talked about before. I know at least 1 forum member here did exactly this job at a local indy. Decide if you want to do the labour to fit them or add that to the quote. It will take you about 2 hours first time to remove the bumper cover, swap over the lights and refit.
Cheers CJ10jeeper, I am just off the phone to my local BMW specialist and have a price for programming. Am I correct to assume the headlights are a direct swap with the ballast etc contained within them and the only additional item on-top of the headlights would be the programming of the car? So it'd just be a case of old lights off, new lights in, pop down to the BMW specialist, have the programming and alignment carried out and job done? It sounds too easy....
gwatson said:Transform your Z4 by fitting these clear front headlights. Will fit pre-facelift car. Takes around 1 hour to fit both and is definitely a DIY job.
£600 plus shipping.
P.S. You must have xenon headlight at present.
Smokin said:My car has xenons and the switch looks just the same as for halogens. When you switch on the xenons that are OEM, they give a little dip downward then upward to "normal". Takes a few seconds for the light to intensify as well. I'm assuming if you get the programming done and they will pass inspection, the light unit is what you replace.
What are the bulbs in the inner space? OEM xenons have a projector lens and NO bulb.
Herminator said:How much of a pain is it to add the self leveling?
cj10jeeper said:Herminator said:How much of a pain is it to add the self leveling?
Never fitted them on the Zed but I suspect it's a rear suspension mounted sensors to calculate body angle changes from a static norm, then you need thge asociated loom - big pain
No flash to pass in the US. Yo must be turning lights on an off that will kill them real quick :thumbsdown:
