Hi all
To fit an oil pressure sensor it looks like I need to remove the air box back to the throttle bodies, how do you get the clips off?
TIF says you needs a special tool, can it be done without?
Can the clips be re used or do I need new ones?
Is this the only way to gain access to the sender sensor area?
What about removing the oil filter casting, any drawbacks to this?
