Hi,
I have a Z4M with a full AP kit that some forummembers know about. For the moment I have Pagid RS4-2 (blue) brake pads on my car for street and track. They are noisy, so I made the decision to change them for better track pads and have chosen RS14 (black). They are almost the same noise level as the RS4-2, but with better initial bite and better heat management on trackdays. I sometimes have some pad deposit from the RS4-2 blues on my rotors from being to hot (results in steering judder).
I have emailed with Pagid ann they advised me to go for the following set-up on my full AP kit; RS14 (front) and RS4-4 (rear).
RS14: http://www.pagid-brake-pads.co.uk/products/rs14-black-ceramic-based.php
RS4-4: http://www.pagid-brake-pads.co.uk/products/rs44-orange-carbon-based.php
The reason why Pagid advice this softer rear set-up:
Some people say this set-up with softer rear pads can cause the rear trying to overtake the front. They say the reason is the following; "Sometimes the back not clamping down can cause it to lift and go light so a less braking rear can give the same effect as a rear end clamping and locking"
What would be the best on a Z4M wit AP front and rear (for track and street)? RS14 all round or RS14 (front) / RS4-4 (rear)? I don't have a pure race car. I have a street car that does 8 - 10 trackdays a year (in the summer). I was planning on switching between pads for street and track. But first I want to see how the RS14 handles and sounds with normal street use... If this feels and sounds somewhat ok, I keep them on all the time.
OPINIONS?
Thanks,
The guys from Simpson Motorsport (UK) have the same opinion;"For the Z4 (and for BMWs in general) a very good track set up is RS14 (black) front pads and RS4-4 (orange) rear pads. A lot of pro teams do that.
Due to the weight transfer during braking the front brakes do most of the job, especially on a front engine car. In our experience the brake balance is better when using less friction on the rear axle. On an ABS car you won't feel so much difference but it is better to stay out of the ABS especially with a none racing ABS.
With the original brake there is less dynamic weight transform (shifting weight to the front axle and reduce it on the rear axle) because stopping power is just not as good. So the OE brake is set up for these road conditions. On the track, in relation to road use, you can use more front brakes and therefore want to have a more aggressive front pad. For instance in race cars with a balance bar master cylinder system drivers turn more brake bias to the rear in slick conditions (e.g. rain) because there is less dynamic weight transfer and consequently more rear brake can be used."
On most BMWs you will find that the AP 4 pot caliper is a little large for the rear, and that a softer pad will generally work better in the rear with the APs.
OPINIONS?
Thanks,
