Removing mould / algae from soft top
Just wondering if this milton fluid method (or the autoglym kit) might also be good for removing the green/algea that can build up on the black rubber/felt window trim which is located above the gap in the door where the side windows slide down into..
- colb
Milton soloution gets rid of the green help it along with a small nail brush then rinse with clean water.
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1999 1.8 Z3
2003 2.5 Z4
Renovo. It’s what all the classic car buffs use. I used it to recolour and seal the roof of an E46 M3. You do need to treat the mould first. Renovo is brilliant stuff though. Then get a sheet to cover the car if it’s outside in the winter.
Did I just post that twice??!!?? No idea what I’m doing most of the time! Sorry
Thank you for the tip I will try that.
2003 3.0i E85 that goes Brrrmm Brrrmm
