You could try emailing Alan Hook at KW. He might be able to find the answers you require. He was very helpful I had a leaking damper in 2020.
[email protected]
KWV3 drop link problem
- BMWZ4MC
S2000 GT - gone
Great I’ll give it a go, when I called I spoke to two different people at kw on the phone and neither of them were sure what I was asking.BMWZ4MC wrote: ↑Sat Nov 18, 2023 11:01 pm You could try emailing Alan Hook at KW. He might be able to find the answers you require. He was very helpful I had a leaking damper in 2020.
[email protected]
2007 Z4M Coupe
Sorry for the delay in replying Inter. No idea if you’re sorted but basically when you buy a set of KW’s, what you need to do is turn the foam packaging inserts over and the drop links are under there…..I know I know….InterlagosMC wrote: ↑Sat Nov 18, 2023 5:01 pm Thanks for the reply, from my understanding the clubsports have a different Mount tab position to the v3 setup which again changes the lengths, I just can’t find a definitive answer annoyingly, will just have to wait until I’m fitting it all and then check for myself.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
So you're all sorted,Johnjohn-e89 wrote: ↑Tue Dec 19, 2023 7:24 pmSorry for the delay in replying Inter. No idea if you’re sorted but basically when you buy a set of KW’s, what you need to do is turn the foam packaging inserts over and the drop links are under there…..I know I know….InterlagosMC wrote: ↑Sat Nov 18, 2023 5:01 pm Thanks for the reply, from my understanding the clubsports have a different Mount tab position to the v3 setup which again changes the lengths, I just can’t find a definitive answer annoyingly, will just have to wait until I’m fitting it all and then check for myself.
Cars mods are coming on well. Some nice APs there
Interlagos Blue M RDSTR,2008. Logic7 dsp Hifi;satnav,stubby,htd seats,etc,etc.
Black 2005 3.0i NOW SOLD(and missed)
Ironically the set arrived this afternoon and I didn’t even see the links in there until I saw your comment, in answer to my original question the links they send are 235mm long for anyone else who may have this same issue, time to send the ones I ordered back and get some shorter linksjohn-e89 wrote: ↑Tue Dec 19, 2023 7:24 pmSorry for the delay in replying Inter. No idea if you’re sorted but basically when you buy a set of KW’s, what you need to do is turn the foam packaging inserts over and the drop links are under there…..I know I know….InterlagosMC wrote: ↑Sat Nov 18, 2023 5:01 pm Thanks for the reply, from my understanding the clubsports have a different Mount tab position to the v3 setup which again changes the lengths, I just can’t find a definitive answer annoyingly, will just have to wait until I’m fitting it all and then check for myself.
2007 Z4M Coupe
- BonkersBM
Bit late to the party, but I had to replace my v3 drop links, and after chasing around KW and Meyle, I fitted the Meyle 316 060 001/HD
