mr12volt install - CD changer coding advice
Online
AnubisZed
Post by AnubisZed » Mon Dec 11, 2023 8:32 am
fatbaldboy wrote: Sun Dec 10, 2023 11:16 pm Do you have a video for connecting the OEM mic?
I'll search for one tomorrow anyway
Jump to 20:40 on this video as I show how to access the mic...
https://www.youtube.com/watch?v=jY-pSPUz0IU
Hope that helps :thumbsup:
Dave
2011, 23i, Grey with Red leather. 8)
RAYK47
Post by RAYK47 » Mon Dec 11, 2023 10:24 am
AnubisZed wrote: Sun Dec 10, 2023 10:55 pm
RAYK47 wrote: Sun Dec 10, 2023 8:52 pm As for what mic I am using, I don't know as AnubisZed installed the box.
:rofl: You're using the OE microphone.
All of the grey boxes use the OE mic, as long as you connect the, included, lead.
:lol: :thumbsup:
fatbaldboy
Post by fatbaldboy » Mon Dec 11, 2023 11:07 am
Perfect, thank you.
AnubisZed wrote: Mon Dec 11, 2023 8:32 am
E89 35i DCT (2009)
Located mainly in SE London and occasionally Hastings
fatbaldboy
Post by fatbaldboy » Mon Dec 11, 2023 12:48 pm
Do you know if this is all accessible from the bimmercode app?
I switched the CDMM changer to the mp3 value and i can see multiple empty CDs in the head unit (so it worked) but no mr212volt interfaces appears.
It was only a quick trial so will look again tonight.
Edit: the mr12volt box is 'on' as the light is lit and I can see it via Bluetooth
Anubiszed wrote: Sun Dec 10, 2023 2:37 pm If you've not got CDC then you need to add 672 to the VO in CAS, NFRM & CIC (and if it's already there, remove 694).
CDMM_ CHANGER_3 is in the file from CIC.
E89 35i DCT (2009)
Online
AnubisZed
Post by AnubisZed » Mon Dec 11, 2023 1:08 pm
fatbaldboy wrote: Mon Dec 11, 2023 12:48 pm Do you know if this is all accessible from the bimmercode app?
Adding 672 to the VO gives you the multiple CD's, as this adds CD Multichanger to the iDrive, thus changing it from one CD (headunit) to 6+ (Multichanger + headunit).
Changing the value of CDMM makes it so it'll recognise MP3's, thus allowing the Mr12volt box to show up (normally in CD1 slot).
So as long as you have 672 coded and added to the CAS, NFRM and CIC (definitely already in CIC as you have multi CD's) and have changed the value in CDMM_CHANGER_3 (make sure it's definitely 3, as there are others) from cdc_vorbereitung to mp3_cdc then it should all work.
Sometimes it does take a moment to appear and sometimes you need to press CD1 option (may even say Mr12volt).
Dave
Online
Chippie
Post by Chippie » Mon Dec 11, 2023 1:12 pm
fatbaldboy wrote: Mon Dec 11, 2023 11:07 am switched the CDMM changer to the mp3 value and i can see multiple empty CDs in the head unit (so it worked) but no mr212volt interfaces appears.
Have you muted the head unit as that then only shows the cd screen.
Online
AnubisZed
Post by AnubisZed » Mon Dec 11, 2023 1:19 pm
Chippie wrote: Mon Dec 11, 2023 1:12 pm
A very good point indeed, as I've done this on installation before :headbang:
Dave
fatbaldboy
Post by fatbaldboy » Mon Dec 11, 2023 6:24 pm
Head unit not muted, I've toggled it on and off.
Still nothing :(
@anubiszed - can I change the VO value with bimmercode, do you know? What is that value?
E89 35i DCT (2009)
fatbaldboy
Post by fatbaldboy » Mon Dec 11, 2023 6:29 pm
My phone is recognising that it's there - screenshot shows that
E89 35i DCT (2009)
Online
AnubisZed
Post by AnubisZed » Mon Dec 11, 2023 8:34 pm
Alas I don't work with Bimmercode, so I don't know how it operates, hopefully someone who does can explain better.
But if you didn't have the multiple CD positions before, and you do now then I'd say you've done something with the VO already.
Just to check, you have done tge following:
Disconnected the Pink LVDS plug from the rear if the headunit and plugged it into the new Y LVDS, and the plugged the other end of the new LVDS cable (greeny blue) into the pink socket of the headunit.
You've unplugged the MOST connector from the old Quadlock connector, then having swapped it into the new MOST Y jumper, plugged the new end into the new Quadlock in the rear of the headunit?
So as your phone can see the Mr12volt box then you are obviously using the new Quadlock Y loom, as this is powering it, so I was wondering if you'd missed some connector out somewhere (as questions above)
Dave
fatbaldboy
Post by fatbaldboy » Mon Dec 11, 2023 10:22 pm
Aaaaasand it was as easy as that.
I'd plugged the MOST connector into the old quadlock instead of the quadlock in the back of the media unit. I only noticed as it was dark out so could see the flashing red light from the back of the unit.
Also the suggestion of @anubiszed had it bang on!
Thanks for your help guys, much appreciated.
No time to feed all the wires and take apart gloveboxes tonight - probably one for the weekend.
E89 35i DCT (2009)
Online
AnubisZed
Post by AnubisZed » Mon Dec 11, 2023 10:50 pm
Excellent, glad you've found the issue :thumbsup:
Dave
RAYK47
Post by RAYK47 » Tue Dec 12, 2023 2:09 pm
:thumbsup: nice, hopefully it will all work now. :thumbsup:
fatbaldboy
Post by fatbaldboy » Tue Dec 12, 2023 4:25 pm
So in summary to my original ask:
I bought a fairly (I think) expensive obd adaptor for £85:
https://amzn.eu/d/55tzfja
I bought the bimmercode app for I think around £35.
My car was already prepped for cd changer from factory. You can see if yours is using mdecoder.com and looking for s694 in the multimedia section.
Using bimmercode to enable the unit to recognise mp3s then makes the multi CD appear in your idrive menu. That's where the MMI unit should show up.
Bimmercode instructions (thanks @b21)
From the 'home' screen of the app:
Headunit -> Expert Mode (toggle) -> 3000 HMI
Find CDMM_CHANGER_3 option and change it to mp3_cdc
CODE -> START CODING
E89 35i DCT (2009)
Online
B21
Post by B21 » Tue Dec 12, 2023 4:28 pm
fatbaldboy wrote: Tue Dec 12, 2023 4:25 pm So in summary to my original ask:
You can code the cd changer using bimmercode.
Not sure it's cheapest way but I'm happy.
To add the changer using bimmercode...
Err that’s what I told you in reply to your original post…. :tumbleweed: :headbang:
Tips for coding with Bimmercode
Headunit -> Expert Mode -> 3000 HMI
A very modified Atacama Yellow 35is :thumbsup:
