Hi, mine is similar. It’s not intermittent, but there is a wobble at c.45-55 which goes away over 60. The steering is a bit vague at lower speeds but OK.
However, this has only happened after replacing all my suspension including the front hubs and kingpins, so I assume it is just an alignment issue. As soon as I get round to it, I’ll book in for a four wheel alignment and hopefully that will sort it.
2003 E85 2.5i intermittent steering wheel wobble
2003 Maldives Blue 3.0i auto
Guys, sticky caliper might be the reason. I took the car for a quick drive and driver's side rotor was scorching hot while all the others were only warm to the touch. I've also raised the front and left wheel is dragging a bit, not a lot but enough for me to notice. I'll order new caliper and report back with the results.
- enuff_zed
Sounds likely.Cebula wrote: ↑Mon Feb 26, 2024 9:56 pm Guys, sticky caliper might be the reason. I took the car for a quick drive and driver's side rotor was scorching hot while all the others were only warm to the touch. I've also raised the front and left wheel is dragging a bit, not a lot but enough for me to notice. I'll order new caliper and report back with the results.
Tbh, I think if it were me I'd do both sides. But that's just me. always do suspension and brakes across the axle.
I'm planing on swapping 330Ci brakes this spring as I track my car a lot. I just want to make sure the caliper is causing the wobble and not something more serious.
- enuff_zed
Hi everyone, I've changed the caliper today and so far the wobble is gone. I'll drive a bit more tomorrow and report back. I'm keeping my fingers crossed it'll stay wobble free
Thanks to everyone who contributed to this thread
2009 09 Carbon Black Cinnamon E86
- Roberltd2
Glad you got it sorted. I had the exact same problem last Autumn. Turns out they were the original calipers. Swapped them out for Febi Bilstein items from Opie oils - problem sorted. Just bought a new set of calipers for the rear now as I can hear one of them staring to drag on the disc as well.
2007 E85 2.5 si Sport in Montego Blue.
1994 Eunos J2Ltd - sold and now undergoing restoration.
1963 Triumph Thunderbird.
After driving the car all weekend I can confirm that the repair was successful
