How to Wire in a Dash Cam (E85/E86)
- srhutch
- Moderator
Re: How to Wire in a Dash Cam
Sitting in the drivers seat it the module to the lower right hand side of the mirror. You should be able to see the purple / white cable once you have removed the two part mirror base cover without stripping any tape.
- Lynchy
Don't know if this helps, I have a pre- facelift with no cruise and I followed Number5s instructions to the letter and no problems at all.
- Number5
In my 2012 5 series I followed the same process but used a green/orange wire, I think..
Recently, someone posted a key to all BMW's wiring colours in here. - Possibly Perry.
If you have a volt meter, its just going to be a case of testing each wire up there with the ignition on and the Neg to the chassis and seeing if anything giving 12v drops to 0v when the ignition key is off.
Alpina Roadster #307
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
10x E85 Se/Si Roadsters
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
- Taz
on a coupe its an easy job to wire it direct to the fuse box
- Number5
I installed //MikerW's dash cam in his 2006 ///M (Post face lift) and that wiring was the same as a Pre-Facelift model, so I don't know why yours is different.
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
- MrPT
Bought a 0806 + hardwire kit and installed it using this guide. Thanks Number5.
For reference, the screw for the GPS aerial grounding point is 8x16, ST4, although it's not very satisfactory using a self-tapper for an electrical contact and I think I'm going to tap mine out properly and use a bolt + locking washer instead.
Has anybody else set their dashcam up for parking surveillance? The 0806 is great, with the exception of the fact that the promised "parking guard" mount and firmware have never materialised!
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- JINGLE
i also have a 0806 and used this guide
i want the parking guard, how do you do it MrPT ?
i thought there was a separate mount to buy?
- MrPT
There is supposed to be one, but it doesn't seem to be available anywhere, hence my question.JINGLE wrote:i also have a 0806 and used this guide
Still... decent camera for the money!
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- rosskins
Number5, great guide and thank you. Followed the steps completely to the book (well almost*) and success first time! Exposing the violet/white wire was fiddly as there is not much room or light in that void but your advice of using a scotch block (Maplins) was bob on and I only needed to strip back a bit of the plastic so it exposed some of the wire. *I soldered an eyelet to the black wire and earthed it around the screw. Brilliant, thanks again. It has inspired me to get my soldering kit out again to sort out the Intravee wake up mod!
- IMG_0091.jpg (78.66 KiB) Viewed 5801 times
Current: F-Type AWD V6 & M135i
Before: ZR3.0si, 525d, 325ti, 120d, A3-2.0DSG, 323T4x4, MX3-V6, 2CV, MetroVP, Mini850
Zed was fitted with: None run flats, Stubby, Cruise, Intravee, DrilledFogs, WiredCam & 326s
- Worcester_spoon
03 Z4R 3.0i/Silver/custom quad/330d brake upgrade/LSD/G-Power supercharger/FIC 365cc injectors/Severn Tuning map
- Greg 01
Great write up .
My camera all fitted and working .
Cheers .
Cheers .
Nachtblau metallic 3.0 si auto ,cup holders , whippy back on
- Number5
You're welcomeGreg 01 wrote:Great write up .
Cheers .
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
- Rorybeanbutler
Great write up. Which cable in my next base box should I be useing for this? I have a hdmi cable. A micro usb/usb and the lighter socket connection. Or do I need to get another cable? Im A bit of a newb with wireing.
z4 coúpe gone. C30 r design arrived.
- Rorybeanbutler
- Rorybeanbutler
