Thank you sirsk93 wrote:It's been added to the OP are requested
![Thumbs Up :thumbsup:](./images/smilies/smilie_thumbsup.gif)
jamiez wrote:Defo does not need to be coded.
Im 95% there on my 2006 3.0si N54 engine.
I just need to stick the wire into the CORRECT pin in the DME but awaiting confirmation before i do so.
The rest of it is a doddle if your OK with cutting, stripping and crimping wires - oh and your eyesight is good!!
Jamie
this document goes on about DME in some amount of detail...jamiez wrote:Defo does not need to be coded.
Jamie
Well... that'll teach them to buy the wrong year.gannet wrote:That's the wrong engine for the facelifts though... Their's is N52.
read the very first page mateyjward wrote:Does anybody know where I can get hold of one of these stacks and how much they cost?
Also, how much would a dealer & independant charge to supply...
Quoted install time on the instructions is an hour, so you'd be looking at an hours labour from your friendly (st)ealer... whats than now.. £80 to £100?jward wrote: ... and fit?
Thanks!
For the sake of 10 seconds it's not worth screwing the DME, I would very much recommend removing the earth.jward wrote:Thanks for the offer, but I'm fairly confident I can do it myself!
I was reading the BMW fitting instructions. One of the preparatory steps they list is to disconnect the negative pole of the battery. This isn't mentioned on this how to guide. Is it necessary?
An extremely valid point.srhutch wrote:For the sake of 10 seconds it's not worth screwing the DME, I would very much recommend removing the earth.jward wrote:Thanks for the offer, but I'm fairly confident I can do it myself!
