AUX DIY
AUX DIY
Hi - new to this forum - I'm trying to fit an Aux-in to a 2006 Z4M Coupe with SatNav, BT & BMW fitted Ipod Cable and am ordering the cable kit from fruity. The problem I'm having is the short length of the cables behind the head unit mean that I can't pull it very out at all and have had to resort to an illuminated mirror on a telescopic handle to view the connectors, making it very difficult to release them, even with a hand up through the lower access panel - is this normal ?
AUX DIY
Are you sure the bulk of the cables are not caught else where? I find when pushing mine back in I have to push them out of the way, which in turn causes them to go behind a part deep in the dash. I then have to pull it out upon removal.
Cables should allow you to get easy pull out access, unless someone's butchered them!
AUX DIY
Thanks - I'll have a look but last time when I tried pulling them I only succeeded in pulling the power lead plug and socket apart.
AUX DIY
Hi,
I've bought a cable from fruity cables and am attempting to fit it.
I've got the vent off and radio out, I'm just not sure where I need to actually put the wires! Car is a 2007 e86 z4 with sat nav. I've attached pictures of what the back of my radio unit looks like. (I pulled out the black clip which I am holding in the second pic, it was plugged in next to the white coloured one).
Thanks for any assistance
- Bmw Z4 aux.png (41.41 KiB) Viewed 5011 times
- Bmw Z4 aux 2.png (42.51 KiB) Viewed 5011 times
- Panta Rhei
AUX DIY
My 2 cents. I have tried everything. Wires with resistors - not working, not recognizing the AUX socket.
AUX DIY
Im trying to fit the fruity cable into the back of my headunit. (The one with the mini satnav screen) i need to know if I should plug the fruity cable's 3 pins into the white or black connector block. Annoyingly in both blocks the corrent pins are empty.
Edit. Its the black one. All sorted.
AUX DIY
Hi guys!
I thought I should make this clear.
If you have a standard unit it comes with a 12 plug. Plug and play as they say.
If you have Navigation, Bluetooth or even both I supply with BMW Crimps, these go into the ore existing block.
White/red to holes 3&4
Black to 10
We will always help BUT sometimes cannot respond instantly due to life etc.
Be safe guys and gals
Black to 10
AUX DIY
So I've took of the vent,removed the plug and replaced with my aux lead plug and it's not coming up with Aux option when I press mode button.
Please help
Please help
