135i Calipers Fitted to Z4M
"M" Specific discussion
Meds
Post by Meds » Sun Jan 07, 2024 11:06 pm
Ed Doe wrote: Sun Jan 07, 2024 11:00 pm Does the disc rotate with the pads in?
Hard to tell as this is all a dry fit, off the car.
I had to rubber mallet them on. Both sides. Seriously tight.
The pistons are fully depressed and sitting flush with the seals, no doubt.
The pads are as far back as possible. The callipers are not connected to the brake line so nothing is pressurised.
The calliper needs to be forced onto the disc, and then forced off again. It's too tight.
Both sides share the same symptom.
After some research, there are a few different pad widths available. Ranging from 16mm to 17mm.
My Brembo pads, part number: P 06 041 are 17mm.
I know someone with a bench sander and I'll head over there to shave a trifle off the pads for an experiment.
Either way, thinner pads will solve my issue and something to note for others doing this uprade.
E86 3.0si - Koni, Eibach, Eisenmann. viewtopic.php?t=143973
F31 340i MPPSK - Carrying family, bikes, kayaks and everything else.
Ed Doe
Post by Ed Doe » Sun Jan 07, 2024 11:20 pm
Really strange - I fitted these to mine with new discs and had no issues (you can see from the specs they were 17mm pad depth too) - that's a real puzzler!
https://www.burtonpower.com/ferodo-ds25 ... 3076h.html
Carbon Black '07 M Coupe: Intrax 1k2 Coilovers, AP-Racing, Raybestos ST45s, Tillets, Schroth, Vibratechnic, Apex EC7, Strongstrut, Eventuri, Supersprint, RTD, 4.1FD :evil:
Silver Grey '06 3.0si Coupe - SOLD :(
Meds
Post by Meds » Sun Jan 07, 2024 11:27 pm
maybe, just maybe the replacement pistons and seals sit further out in the calliper body than the OEM pistons and seals?
And this was not noticeable when using the thinner discs I was using before, 26mm from memory.
And that's what's causing my lack of room for the 28mm CSL disc. ?
Ed Doe
Post by Ed Doe » Sun Jan 07, 2024 11:37 pm
Meds wrote: Sun Jan 07, 2024 11:27 pm maybe, just maybe the replacement pistons and seals sit further out in the calliper body than the OEM pistons and seals?
Yeah that could be it, I forgot to ask (I've not read back over the thread in a while!) if you'd had them refurbed and if the seals were definitely seated right...!
I think all things being equal, a tickle of the pads with a sander sounds like the best solution, if you can't drive the car with the pads as is...
Meds
Post by Meds » Mon Jan 08, 2024 9:44 am
Ed Doe wrote: Sun Jan 07, 2024 11:37 pm
Here they are, but with the calipers not budging, they're stuck on and the only way to remove them is either a tap from a rubber mallet or man-handle them, rolling around the floor like a Jiujitsu fighter . :rofl:
Over the next few days, I'll hopefuly get the pads sanded a touch, then go from there.
Meds
Post by Meds » Mon Jan 08, 2024 10:51 am
The plot thickens..
It's not the pistons that are preventing the pad moving outwards enough. It's the groove in the caliper where the pads slide, there's a small shoulder that prevents the pads moving any further outwards.
My pads are firmly against this shoulder.
Pads are 17mm and disc is 28mm.
My only option is thinner pads.
Ed Doe
Post by Ed Doe » Mon Jan 08, 2024 11:12 am
Can you grind/fettle the pad backing plate to clear the groove in the caliper?
Looking at that photo it also looks like the screws are pushing into the pad backing plate too - can you wind them out a bit?
Meds
Post by Meds » Mon Jan 08, 2024 11:21 am
Ed Doe wrote: Mon Jan 08, 2024 11:12 am Can you grind/fettle the pad backing plate to clear the groove in the caliper?
I'm not sure I can, that shoulder looks to serve a purpose and if the pads are allowed to move inside it, it may case rattle/squeek ?
It looks like my pistons are exactly inline with this shoulder, too. So even if I did that, it wouldnt give me any more room. :headbang:
Yes, the photo does show the pin threads protuding into the pads, but they're not. loadsa room behind them. I think the photo perspective is kidding us.
Ed Doe
Post by Ed Doe » Mon Jan 08, 2024 11:26 am
Stupid question, but you definitely have the pads the fitted the right way up? :lol:
Ed Doe
Post by Ed Doe » Mon Jan 08, 2024 11:34 am
Dunno if any of these pics help, it's all the pics I could find of my old setup (after I took them off prior to selling the car). I'm not quite sure if mine had the same ledge as yours or not...?!
Meds
Post by Meds » Mon Jan 08, 2024 11:36 am
Ed Doe wrote: Mon Jan 08, 2024 11:26 am Stupid question, but you definitely have the pads the fitted the right way up? :lol:
Yes, all present and correct.
maupineda
Post by maupineda » Tue Jan 09, 2024 6:22 am
I had a similar issue where it was a tight fit, it was not that bad to the point it would not rotate, I assembled and drove it slowly for 20-30 miles, and all bedded in correctly. I am sure the next pad change it won’t be an issue as the disc wears off a bit, or as you have mentioned, file the pads down 0.5 - 1mm and all will be good.
Meds
Post by Meds » Tue Jan 09, 2024 11:19 am
maupineda wrote: Tue Jan 09, 2024 6:22 am I had a similar issue where it was a tight fit, it was not that bad to the point it would not rotate, I assembled and drove it slowly for 20-30 miles, and all bedded in correctly. I am sure the next pad change it won’t be an issue as the disc wears off a bit, or as you have mentioned, file the pads down 0.5 - 1mm and all will be good.
Interesting to read that yours were also tight. Thanks for sharing.
We all know this conversion is a tight squeeze but maybe there's some manufacturing differences among the 135i calipers or pistons that result in some being tighter than others.
They'll rotate once on the car, but I can imagine it'll take a good heave on the wheel rather than it spinning free. It's very tight.
I have everything ready to sand the pads down, just a trifle, .5mm will be fine.
Belt sander and verniers at the ready. But it's flipping cold today (I want to do outside), and I'm rammed with work, so maybe a weekend task.
B21
Post by B21 » Tue Jan 09, 2024 4:24 pm
I've come to this late..I use the same calipers on my 35is..are you using some custom pads?
A very modified Atacama Yellow 35is :thumbsup:
Meds
Post by Meds » Tue Jan 09, 2024 4:40 pm
B21 wrote: Tue Jan 09, 2024 4:24 pm I've come to this late..I use the same calipers on my 35is..are you using some custom pads?
No, OEM pads here.
Brembo in my case. 17mm thick.
