EcuWorx remap for Z4M
Next week is great!
Too bad for shift light, would be useful in a roadster where sun can get in the way of using all of endless rpms of s54
Hi Martyn, would 100% be interested in this!
- Ed Doe
Do you know if evolve are amongst these? And if so, are you able to flash the oe map back on before tweaking?Martyn wrote: ↑Thu Oct 06, 2022 12:47 pm Tough to give an exact date but maybe in the next week or so potentially.
Providing the ECU is not locked to prevent reading by a previous tuner (a few do this to protect their IP) you'll be able to tweak freely. Naturally this won't effect existing tuning (ignition, vanos, fueling etc).
I'm also definitely interested in either beta testing or paying for a tune eventually, my evolve one is fairly s**t, throttle is way way too aggressive even in comfort, and it also feels completely non-linear which can make it really challenging to balance on the throttle or drive on broken roads. Plus there's a soft limiter instead of proper hard one like the oe map. I'd definitley be interested in sorting the throttle out whcih it looks like you can, as well as possibly a slight rev limit raise. Also innterested in enabling mtrack mode if that's something you could do!
Carbon Black '07 M Coupe: Intrax 1k2 Coilovers, AP-Racing, Raybestos ST45s, Tillets, Schroth, Vibratechnic, Apex EC7, Strongstrut, Eventuri, Supersprint, RTD, 4.1FD
Silver Grey '06 3.0si Coupe - SOLD
- Martyn
It usually depends if you were sent a flashing cable (Evolve-R) or went to Evolve for the tune, if it was done remotely it's lilkely to be locked, if you went to their HQ then it probably won't be.Ed Doe wrote: ↑Sat Oct 08, 2022 1:46 pmDo you know if evolve are amongst these? And if so, are you able to flash the oe map back on before tweaking?Martyn wrote: ↑Thu Oct 06, 2022 12:47 pm Tough to give an exact date but maybe in the next week or so potentially.
Flashing back to stock in order to allow you to tweak is no drama at all.
M-Track is an interesting one, I'll cover that in another post.
- Ed Doe
The Car was mapped by Evolve when it was with it's first owner, with before/after dyno runs, so be fairly sure it was done at their premises Either way it's not the best tune so I'd be happy enough skipping it! Very keen to hear from you once you've finished development, please do keep us all posted!Martyn wrote: ↑Sun Oct 09, 2022 9:06 amIt usually depends if you were sent a flashing cable (Evolve-R) or went to Evolve for the tune, if it was done remotely it's lilkely to be locked, if you went to their HQ then it probably won't be.Ed Doe wrote: ↑Sat Oct 08, 2022 1:46 pmDo you know if evolve are amongst these? And if so, are you able to flash the oe map back on before tweaking?Martyn wrote: ↑Thu Oct 06, 2022 12:47 pm Tough to give an exact date but maybe in the next week or so potentially.
Also interested in MTrack stuff - will keep my eye out for the separate post
- abar121
That tool looks wonderful! Great job!
'07 Z4M Interlagos Blue. All options except extended leather.
Any progress on this? I’ve used your software on my m3 and really want to do the same on my Z4M
Thanks!
Thanks!
- Martyn
Still in progress.
I've been tied up with some other bits, but it will be coming!
Hi, any updates on this?
Martyn wrote: ↑Wed Jun 29, 2022 3:42 pm Continued testing my AlphaN tune, but switched over to a GSR box. As some of you know the boxes are made to fit the E46 M3 and not the Z4M so the snorkle piece doesn't fit.
I initially hacked the snorkle up a bit to give it the clearance but decided a better solution would be to design and 3d print my own version.
Hi Martyn - have sent you a DM. Hope that you might be happy sharing the 3D print file so that I might be able to print one of these locally in NZ! Thanks in advance.
Hi all,
Having come back to the forum in search of another Z4MC, I can see this thread carried on and looks very promising.
Has there been any finalised solution using the stock Z4M DMEs yet? as I when I get another one, a carbon air box is definitely top of the list!
I think the ability to map yourself and switch between using a MAF/Alpha N would be great, as it would make for a much easier process when installing/removing the full "CSL" carbon air box yourself.
From the brief research I've done again, it seems places that can map these with Alpha N still seem few and far between, and costly, so failing the self mapping software above, does anyone have any recommendations for a tuner that can map these with all the extra features like the rev limit increase, etc. (preferably down south)?
Thanks in advance
Thanks in advance
When went down the Alpha N route with mine I had Aaron from Areeves in Kings Lynn carry out the mapping and set up.
Great bloke,highly respected and recommended.
2007 M Coupe
Interlagos Blue,Sepang leather,carbon leather trim
I went down the Evolve Automotive route with my Z4MC and was hugely impressed. Imran and his team really do know what they are doing.
https://www.evolveautomotive.com/produc ... 0613687587
Everything is supplied to do this yourself. The real benefit is their brilliant software interface easily downloaded onto your laptop. Kit includes OBD dongle, transfer cable, IAT sensor, and IAT extension cable (which I didn't need). Software downloads (and saves) your original tune. Email this to Evolve who modify to Alpha-N (and other mods if required) and return for simple download through your laptop back to the car. My tune was returned to me in less than 24 hours. 100% seamless and problem free process and car has never run better. I wouldn't hesitate recommending to anyone that wants to go the same way.
Ah yes, I seem to recall seeing they did this - how much do they charge for the tune?
I think my preference would still be to use the EcuWorx tool, as I could install/remove the airbox myself, save the trip and cost.
Thanks for that.bestgun wrote: ↑Thu Jun 15, 2023 9:39 pm I went down the Evolve Automotive route with my Z4MC and was hugely impressed. Imran and his team really do know what they are doing.
By any chance do you know if the EvolveR tool has the tune vin locked? As if it's something I could sell on afterwards, the cost wouldn't be too bad. For example, the Cobb accessport I used to tune my 981 GT4 wasn't vin locked, so I bought it used and will likely sell it on for what I paid.
It's probably worth noting for context that I'm trying to find a solution for the full carbon air box (so AlphaN) that I can install/remove easily, as I wouldn't get the value back leaving the air box on the car as and when I came to sell.
