Uh oh. Bennys' first tantrum! WAYHAAAY We're back in business! :) EDIT: 2000 mile update.
- Chris_D
Uh oh. Bettys' first tantrum! inc updates...
Hi MM.
A 2nd hand TB literally just turned up this morning via ups from lithunia of all places.
Bought on fleabay for gbp50, its 2 years newer than mine. From a 2005 x5. A bit grimy and (i hope) original condition as there seems to be a minimal amount of brown varnish on the butterfly. Much less than was on mine at any rate.
It sounds rock solid too. No rattling of loose internals. Mine had a very feint rattle, like a spring inside had worked its way loose.
I'll give it a good clean but i have a new tb gasket and cam/crankshaft sensors and diagnostics bumpf coming so i might just wait til that lot lands.
One thing i remembered from the recovery guy is a mumbled statement from him along the lines of a '24% difference in the signal between the tb and the tb actuator'
Was he referring to the pedal when he said tb actuator? I know its fly by wire. Where are the tb position sensor/s located? Maybe they will need replacing if it turns out not to be the tb......
![Image](https://i.ibb.co/ZN0ccvp/IMG-20180428-161347-EFFECTS-1-1.jpg)
- Chris_D
Gah, forgot to quote u. Question in my last post.see above....Machine monkey wrote:Thats exactly what mine was doing have you changed the TB yet? I will be surprised if that dose not fix the problem.
- Machine monkey
No idea mate was not there??????Chris_D wrote:Hi MM.
But it could be the TPS or it could be the TB like i have said mine was getting weird voltage readings because of a bad earth could be that too?
- Chris_D
where do i find the TPS? at or in the pedal? or somewhere else?Machine monkey wrote:No idea mate was not there??????Chris_D wrote:Hi MM.
and where the jiggery do i locate that groundpoint in the boot u referred to? do i need to pull up carpets at back right of boot?
- Machine monkey
i guess the pedal but i dont know.
Just follow the cable from the battery its under the carpet in the boot to the left.
- Chris_D
Update.
Well, the results are in and I'm afraid to say at this point in time it's a bit of a mixed bag.
The replacement TB seems to have cured the pulsating, rough idle problem. Nice one MM! I think you were right there!
However....and it's a BIG however. A few minutes into sitting and idling a sh*tload of oily smoke started coming from between the driver side of the engine block and the heat shield. Pouring out at first then after switching engine off receded a bit. One of my neighbours came out to enquire- that's how serious it got. lol
I removed the dipstick in it's entirety during the fix and there was a bit of spillage over the sump cover and down into the pan so maybe there's a pool of oil i missed mopping up. However, the spillage was on the passenger side and the smoke was coming from driver side.
So, next step. let it cool down and inspect the valve cover gasket tomorrow to see if there is any leakage occuring. Got a feeling the gasket might have breached. However, a mate's just advised to give a good spray of brake cleaner where I think the oil spill may be located and leave overnight to dissipate, then crank up again and observe... what do you reckon?
Somewhat encouraged but on the whole, still a bit concerned.
First start-up after TB replacement:
[youtube]https://youtu.be/YpahPQrbM4c[/youtube]
https://www.youtube.com/watch?v=YpahPQrbM4c
Shut down engine after observing smoke:
[youtube]https://youtu.be/Fbp5nKHHuW4[/youtube]
https://www.youtube.com/watch?v=Fbp5nKHHuW4
- Machine monkey
Humm it is a bit of a mixed bag. Firstly clear any faults that might get rid of the engine light. Obviously check everything's tight no leaks anywhere on the intake system. And also just double check all the connections are on tight.
Its very hard to see much smoke from the video. But a little oil can make quite a bit of smoke on a hot manifold. I think your right to let it cool down. Dont panic yet and i am sure you have fixed it it just needs ironing out.
Good work buddy and i am pleased the TB did work as i was pushing for that!! I was starting to worry it wouldn't!!
- Chris_D
Yess, and I'm grateful you were pushing for the TB replacement. Was baulking at laying out Eur300 for a new one and getting a 2nd hand one at about Eur60 was a good tactic I think.Machine monkey wrote:Humm it is a bit of a mixed bag. Firstly clear any faults that might get rid of the engine light. Obviously check everything's tight no leaks anywhere on the intake system. And also just double check all the connections are on tight.
Will look out for oil leaks and pools tomorrow morning when its cooler and check connections.
Used the 2 good T40 bolts as replacements for the ones I had to cut a slot into for the DISA and re-used the 2 cut ones on the ICV bracket (snug tight, easy to release). Have some new T40's on order but might try and source alternatives - hex, crosshead with same thread pitch and length. Screw Torx bolts in the future!
I have a sneaking suspicion that the CCV system is the source of the smoking and will need replacing as I've experienced that twice now on my old E36 coupe and the M3. Had to replace both.
Watch this space.....ho hum
- enzed4
Chris - when you quote a youtube video, just put the last bit after the = sign between the youtube quotes.
Cheers.
Cheers.
Chris_D wrote:Update.
![Image](https://live.staticflickr.com/7855/47496384231_2d555311ce_m.jpg)
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
- Chris_D
enzed4 wrote:Chris - when you quote a youtube video, just put the last bit after the = sign between the youtube quotes.
Cheers.
Will do! Thxfor the tip!Chris_D wrote:Update.
- Machine monkey
So then Chris what was the outcome?
- Chris_D
well, still smoking after spraying around bottom of head with brakleen. noticed a fresh seepage of oil this morning at the back of the head just under the gasket location so def leaking.Machine monkey wrote:So then Chris what was the outcome?
pattern-torqued the bolts an 1/8th turn each and then ran again. same result - oily smoke, although not as much.
idles great now tho around 900rpm
![Thumbs Up :thumbsup:](./images/smilies/smilie_thumbsup.gif)
but i'm gonna get it booked into a garage i've been using here for years as what needs to be addressed is going to take ages - and i dont move that fast cos i'm not a mechanic - slow and steady is my modus sadly.
asked them for a quote on
cylinder cover gasket replacement
oil filter housing gasket replacement
ccv replacement
front pads need replacing
waterpump and thermostat
compression test (just to satisfy curiosity and set a milestone)
guess about euro800-900 for that lot. fingers x'd.
i'd love to tackle those issues as you say it's great learning and character building but i fear it would just take me a month of sundays to complete and i'm coming out of my 'work-hiatus' at this point in time and need to focus on getting some contracts in....
might just leave the ccv replacement for myself, cos it looks like a proper challenge.....
whaddyareckon?
- Marlon
Water pump and thermostat parts alone will knock you back £350 minimum
Gone: 3.0si 2008 E85
911 997 Carrera S
- Chris_D
Marlon wrote:Water pump and thermostat parts alone will knock you back £350 minimum
ah sorry,
should have mentioned; i bought some parts already as i intended to do those jobs myself.
Only things i dont have are the ccv kit and cylinder head gasket. got everything else including 'klein montage' (bits n bobs)
- Chris_D
So after a couple of days observation there definitely seems to be a leak from the valve cover gasket.
Was at the stage of leaving it and a few other jobs to a local garage to fix but after reading a few threads here and over at Bimmerfest I'm buoyed up to have a crack at it myself.
As mentioned before I'm not a mechanic but I'm willing to have a go. As any of you who have been following this thread will know by now I managed to replace the throttle body with a few twists and turns and stripped bolts thrown in! I've done other small service items previously but have usually left anything more complex, such as this to the experts.
Anything I should be aware of before starting?
I'll be sourcing some good quality parts including the gasket kit, rubber grommets, washers and bolts, RTV sealant required and a new can of brakleen. Good idea to give the inside of the valve cover a good clean as well as all mating surfaces?
This guy on bimmerfest has a leak in EXACTLY the same location as mine. After watching the bavsport vids I feel pretty confident about havin a go. Any thoughts, nuggets of wisdom, experiences, lessons learned?
http://www.bimmerfest.com/forums/showth ... p?t=802082
