135i Calipers Fitted to Z4M
"M" Specific discussion
Ed Doe
Post by Ed Doe » Tue Jan 16, 2024 5:32 pm
Meds wrote: Tue Jan 16, 2024 5:17 pm
Ed Doe wrote: Tue Jan 16, 2024 4:36 pm , and then bought the epytec.de ones you've bought :thumbsup
But you were running these on your M.?
Or non-M. ?
No mate, I was running the BMW performance calipers on my old 3.0si!! I've got AP-Racing brakes on the M :thumbsup:
Pics of my old one:
Carbon Black '07 M Coupe: Intrax 1k2 Coilovers, AP-Racing, Raybestos ST45s, Tillets, Schroth, Vibratechnic, Apex EC7, Strongstrut, Eventuri, Supersprint, RTD, 4.1FD :evil:
Silver Grey '06 3.0si Coupe - SOLD :(
Meds
Post by Meds » Tue Jan 16, 2024 7:02 pm
Ahhh, got it...!
They look beautiful! :thumbsup:
E86 3.0si - Koni, Eibach, Eisenmann. viewtopic.php?t=143973
F31 340i MPPSK - Carrying family, bikes, kayaks and everything else.
Ed Doe
Post by Ed Doe » Tue Jan 16, 2024 8:05 pm
They worked brilliantly too, road and track! Once you've got through your teething issues you'll be chuffed with them I'm sure, keep going :thumbsup:
Nictrix
Post by Nictrix » Tue Jan 16, 2024 11:01 pm
Meds wrote: Wed Jan 10, 2024 1:59 pm You can get brackets that allow the 330i 325x25mm disc.
This would solve my problem, easily.
But, if we're gonna do this, lets dot it! - 345x28mm CSL disc it is!
(but I need to break out the belt sander and shave .5mm of the pads, first.)
Could you remove the pad shim to give more clearance?
3gGT01
Post by 3gGT01 » Wed Jan 17, 2024 1:50 pm
6 piston looks great! :thumbsup:
2007 Z4MC Interlagos Blue Metallic w/Light Sepang Bronze Nappa interior. 'Emma'
Meds
Post by Meds » Wed Jan 17, 2024 1:53 pm
Nictrix wrote: Tue Jan 16, 2024 11:01 pm Could you remove the pad shim to give more clearance?
I think I can, but is that there for vibration/squeal reasons?
Nictrix
Post by Nictrix » Wed Jan 17, 2024 5:28 pm
Meds wrote: Wed Jan 17, 2024 1:53 pm
Anti squeal shims I think.
Copper slip might do the job instead until the pads have worn s bit.
Ed Doe
Post by Ed Doe » Wed Jan 17, 2024 5:50 pm
I'm guessing mine must have been removed because I didn't have the fitting issues, but if it helps I never had squealing issues with the oe pads. Ds2500 were a bit squeaky but that never really bothered me.
Meds
Post by Meds » Wed Jan 24, 2024 3:53 pm
Pads ground down to 15.8mm on the sander. The callipers now slide over the disc like a dream.
The brackets have arrived, too.
Scheduled install for the 15th Feb. Whoop whoop.
Ed Doe
Post by Ed Doe » Wed Jan 24, 2024 3:56 pm
Excellent! Get some pictures up once fitted!
Meds
Post by Meds » Fri Feb 16, 2024 11:33 am
Whoop whoop......
I've hardly driven them but initial impressions are good.
Although I do have a longer pedal, the power is there but there's more pedal travel to get it.
I'm not sure if this is a characteristic of these callipers on the 3.0si or maybe a 2nd bleed is needed.??
Online
B21
Post by B21 » Fri Feb 16, 2024 11:42 am
On the E85 Z4M is there an option like on the E89 to enable ‘performance brake’ option in the DSC system?
I changed mine to that option when I fitted those calipers…
I certainly have a firm pedal..
A very modified Atacama Yellow 35is :thumbsup: Previously a slightly less modified Atacama Yellow 20i MSport :thumbsup:
Ed Doe
Post by Ed Doe » Fri Feb 16, 2024 12:31 pm
Meds wrote: Fri Feb 16, 2024 11:33 am Whoop whoop......
Wooo finally got them on, congrats! They look very smart too :)
What did you have to do to make them fit in the end? shave a few mm off the pads?
I found my pedal was a little longer than previously with the OE calipers, but that's because you're moving more brake fluid with the 6-piston calipers than the single piston OE calipers. I actually found it a nice improvement once used to it, as it permits better pedal modulation.
Can't comment on the performance brake coding, I never bothered.
Meds
Post by Meds » Fri Feb 16, 2024 12:36 pm
B21 wrote: Fri Feb 16, 2024 11:42 am On the E85 Z4M is there an option like on the E89 to enable ‘performance brake’ option in the DSC system?
Mine is firm, but further away than it was yesterday. :rofl:
I'm a noob when it comes to coding, and I suspect the E85/86 platform has a more limited set of variables, so this might not even be an option.
Ed Doe wrote: Fri Feb 16, 2024 12:31 pm
Interesting, thanks for the info, Ed.
tomscott
Post by tomscott » Fri Feb 16, 2024 1:33 pm
They look great, I would like to do this to my M at some point
