Atacama Yellow 35is build thread
- B21
The journey back begins…re-covered dash goes back in…Bondarised plastic lugs hold up…after forgetting some key cables for the centre speaker necessitating a removal and re-fit the dash is home and secured ..only got to put everything else back now..
Very hard work trying to get the new leather with 3mm foam to fit in and around the various orifices..very glad I used a professional rather than trying my luck..
Put lots of sticky backer felt tape to deaden the rattle of plastics..
- IMG_2512.jpeg (171.71 KiB) Viewed 677 times
- IMG_2510.jpeg (186.75 KiB) Viewed 677 times
- IMG_2509.jpeg (218.51 KiB) Viewed 677 times
A very modified Atacama Yellow 35is Previously a slightly less modified Atacama Yellow 20i MSport
- B21
The instrument cluster binnacle was re-covered as part of the dash..but the leather /foam made it impossible to refit the oiter cover of the unit to the inner part of the structure..lots of clamps required..
- IMG_8739.jpeg (257.3 KiB) Viewed 651 times
- IMG_8738.jpeg (252.82 KiB) Viewed 651 times
- B21
The journey continues..I revisited the bond(ar)ing of the c/f fronts to the various switches..I used a hot glue gun and with the clamping force and flex they were starting to separate ..this time it’s epoxy resin..and clamps..the mother f@€kers shouldn’t move this time..
Next in line was the fitment of the ID4Motion cluster to the removed instrument binnacle…the problem (among many) is that the novel construction of the adapter results in about 3-5mm float / jiggle between the body of the cluster and the binnacle…so resorted to a bit of silicone mastic and yet again some trusty clamps..
Dash now fitted..I thought I’d lost the starter cable so took it out again..only to find it lying on the floor..
The A pillars were covered in leather..boy what a bitch to make them fit..I guess not surprising that if you keep adding material then it’s going to cause issues..
So yet more clamps required to hold A pillar covers in place whilst top windscreen trim put into place..now the self tapping holes that hold the sun visors in place are too loose..so have to order some fractionally thicker torx headed self tappers..
As an aside ..have you ever tried to balance a male headed torx bolt on its socket to try and start a difficult to reach bracket…ie the steering column brackets..it’s a bitch....
Despite all this I am enjoying this..I think..
- IMG_2513.jpeg (154.24 KiB) Viewed 611 times
- IMG_2514.jpeg (124.65 KiB) Viewed 611 times
- IMG_2515.jpeg (123.44 KiB) Viewed 611 times
- IMG_2516.jpeg (144.41 KiB) Viewed 611 times
- cc5ecec3-ae58-4164-bacb-636b12629624.jpeg (173.75 KiB) Viewed 611 times
- IMG_2517.jpeg (173.19 KiB) Viewed 611 times
- Nanu
One day, perhaps in the distant future, you may actually get to drive the Yellow Peril and think, yes this is the car I want. Finished!
G29 M30i M Sport San Francisco Red
Previous
E89 35is Valencia Orange
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
- B21
Car starting to come alive..bad news is that the CIC unit that powers the radio/sat nav etc is dying…I tried a fresh disc but no cigar..got a second user one to fit..
DSP/amp with MOST bridge powered up..no sound for sometime (ignoring the CIC unit only works for 15 seconds every 5 minutes)…but a firmware update to the remote controller and it burped into life..
Plenty of set up required but the audio sounded very meaty..
- IMG_2534.jpeg (131.6 KiB) Viewed 515 times
- IMG_2535.jpeg (155.37 KiB) Viewed 515 times
- IMG_2532.jpeg (194.3 KiB) Viewed 515 times
- IMG_8757.jpeg (165.04 KiB) Viewed 515 times
- f21a5e33-f19e-4aa1-a489-67c9fcf50b09.jpeg (111.8 KiB) Viewed 515 times
- Jollyjoiner
I'm glad someone knows what their doing , look at all those wires
2009 35i DCT silver
SLT mapped to 365bhp
- ronk
I thought there’d been an explosion in a spaghetti factory!Jollyjoiner wrote: ↑Tue Mar 05, 2024 10:33 pm I'm glad someone knows what their doing , look at all those wires
Looks like its coming together now, brilliant thread Peter.
M40i sapphire black,tech,comfort shadow line.
- B21
Yup it’s never easy ..thank god the adapter harness got so far..Jollyjoiner wrote: ↑Tue Mar 05, 2024 10:33 pm I'm glad someone knows what their doing , look at all those wires
- B21
Yup the light at the end of the tunnel is the train coming towards you!
- Nictrix
I thought the light at the end of the tunnel was just some bugger with a torch bringing more work
- B21
In my case both…
- Nanu
The lads at Performance Centre were asking after you today when I took mine in for a service.
Told them you were doing something which I didn't understand and from the images, I don't
Previous
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
- B21
B21 IS the Reassembler!
Coming back together …rear cabin cinched up…
New c/f covered roll over hoops with nice leather fronts with themed yellow stitching..
Rear cam now mounted neatly …
Remounted spoiler..my god that 3M tape sticks ..I’ve got the rear slightly mounted off the line on the boot in the middle..looks like a custom diffuser gap…only visible to moles..
- IMG_2538.jpeg (123.93 KiB) Viewed 366 times
- IMG_2539.jpeg (135.8 KiB) Viewed 366 times
- IMG_2540.jpeg (120.59 KiB) Viewed 366 times
- IMG_2541.jpeg (123.25 KiB) Viewed 366 times
- 1536Z4
Looking like a car again and very nice too. Good job
Montego Blue E86 . MILV`s . Simpson Custom Manifold Race Exhaust . xHP transmission stage 3 . VT engine mounts . BC RA coilovers . H&R arbs . Adjustable rear camber arms . Ultra Racing front strut brace . Drexler LSD .
