Side covers - 3D printer
HI all,
We now have a 3d printer in the office at work. Does anyone would like to lend me some top down side covers as a mould?
Then I can look at making some for members much cheaper then OEM.
Its only £14 for 1kg of plastic so should be cost effective
- 1000rr
Interested.
- srhutch
- Moderator
What is the max dimensions you can print?
- 85genius
Couple of guys willing to sell so maybe prepared to lend to you first for a good cause!
Audi quattro driver
NOW SOLD - Ruby Black 3.0 SI Roadster
Previous - E85 2.5 Ti Silver - See avatar photo - R.I.P Destroyed by a Tranny
Also interested once available!
Alpina Roaster S Lux #310 - Titanium Silver
E85 2.5i Titanium Silver 2003 - Sold Feb 2018
- Johnbmwz4
I'd buy some. These will sell like hot cakes
BMW E89 3.5i M Sport manual, loving it….
Audi S5 Cab, Great car but not special enough….
BMW E89 3.5i DCT, Havana Brown, should never have sold it…..
BMW E85 3.0 Auto, sadly missed (twice)
- Ducklakeview
Seem to remember this being attempted before, and the problem being getting a printer big enough to do them in one piece?
Mike
Mike
- Chris_D
I thought about doing this as the company I'm doing some work for at the mo, Ultimaker, have given me a UM3 Extended to play with.
However, even with the extended build volume I calculated that it would take eons and using ABS would probably not yield fantastic results in terms of rigidity etc.
I have a few experimental print heads including one with ruby heads designed to use carbon-fill but I doubt it would last beyond two sets of covers.
The cat still loves it as a playhouse however
Good luck with the venture. Be interesting to see how your results turn out....
- Chris_D
zactly larDucklakeview wrote: ↑Wed Jan 17, 2018 6:04 pmSeem to remember this being attempted before, and the problem being getting a printer big enough to do them in one piece?
Mike
- Vornwend
Also interested. I also wondered if we could get a Chinese company interested in a group buy? Might be a reasonably big worldwide market for these?
Now: 2004 Z4 3.0i - Merlot Red
Before: VW Corrado VR6 Storm - Classic Green
- MrPT
Not sure our printers would print that size either. I'm sure ABS will be rigid enough, it would just take ages at the required res and thickness. Then it would need smoothing or covering in something like Alcantara.
I reckon the covers would vac form well. You could just print the fixtures. Or even 3D scan and print a single pair of custom moulds for vac forming lots of covers.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
Think the idea would be to get a set scanned and then modify the B surface in CAD to rib and thicken them up to make them stronger. The external will look the same. Perhaps device a better fixing as well. Wouldn't take much to get a quote from a rapid proto house once you have a 3D CAD model, either as parts or a tool to make a batch. Thought about it myself, just haven't got a set to get scanned!
57 Plate 3.0 Si Auto SilverGrey - Red Leather
E89 35iS Space Grey - Red Leather. SOLD
56 Plate 3.0 SI Manual - Black with Red Leather- Scorpion exhaust, BC coil overs SOLD
54 Plate 3.0 SE Auto - Silver with Red Leather. SOLD
Id be up for a pair if this gets off the ground.
Good luck with it.
Good luck with it.
Maybe you should be asking for lots of photos and measurments from someone who has them, the printing isnt the difficult part there are lots of prototyping companies that produce things really cheaply these days once you have the detailed 3d files.
Alpina Roadster S LUX #030
