How to modify your CDV (Clutch Delay Valve)
srhutch
 East Sussex, UK
This is the one you have all been waiting for.
I have posted this How to Do in this section to ensure maximum exposure.
This valve is from a non M Z4, although I am assuming the process would be the same, if someone want to send me a M valve, I will test.
Although this is a simple process I do not accept any responsibility for any damage to you, your vehicle or any third party if you carry out this procedure.
I would also like a couple of our members to validate this process. I know our leader has a spare one, or at least one that requires modification.
I would suggest that you do this process on a spare valve just incase you do run into trouble. There are enough Z4 owners out there that have changed this part so hopefully you could find someone who will either give you their old one or loan you one until you take yours off.
If however you wish to purchase one from your dealer the price I obtained is £7.79 + vat. There is no stock in this country so delivery would be 3-4 days.
Unfortunately, I wasn’t present when I got my guy to remove this as I thought it was going to be harder than it was and therefore left him to it. But once I have changed mine, I do intend to carry out this procedure, after which I will happily donate. I would however suggest that all owners generally modify their own to prevent any problems with comeback etc.
This is a simple process that requires no special tools other than a hammer and two drills bits of 3.5mm and 9mm NO DRILLING IS INVOLVED. If you have ever replaced a wheel bearing this should be a simple procedure.
Fig1. shows a sectional view of the valve, the device and principal are both simple. When you depress the clutch the piston (C) moves towards the insert (B) due to hydraulic pressure which allow hydraulic fluid around the piston due to its design, when you remove your foot from the clutch the hydraulic pressure forces the piston back which forces the hydraulic fluid through the 1.5mm diameter hole. There is no spring in the valve; the force of the hydraulic fluid alone moves the piston to its required position.
The insert does two jobs, to retain the piston, and locate and seal the rigid hydraulic pipe. As it located on a step when the insert is refitted it will be in its original location. The insert is retained only by the slight interference fit with the body so is easily removed and reinserted. The slight interference is confirmed by the fact the piston has retained most of its shape after removal, if this had required a lot of force the piston would be have deformed more before the insert was removed and would probably be flat.
The process:
Insert the 3.5mm drill bit into the end with the male thread (small bore) ensuring you insert the flat end of the drill. If you insert the pointed end you will probably damage the piston and it will then be impossible to remove successfully.
It is possible to use any cylindrical object that fits the bore with a snug fit and has at flat end to locate against the piston. A screwdriver with the end ground of may also work.
By gently tapping the drill with a hammer will push the piston and insert out of the bottom. Be aware that this will probably damage you drill bit. It would be advisable to hold the valve in a vice if possible, it does not need to be done up tight, as the hex flats will locate above the jaws and prevent movement. Doing this will allow the piston and insert free exit from the body.
Once you have removed the piston you then use the 9mm drill bit again with the blunt end against the insert and tap back into place. Ensure you insert the valve the correct way with the chamfered bore facing out. It maybe easier to use a socket if the outside diameter is around 9mm as this will have a flat end top and bottom, but ensure it will fit inside the bore before attempting to refit. Again you need to use something like this for two reasons; one is so the flat bottom locates on the flats of the insert to prevent damage to the sealing chamfer, and also to ensure the insert is inserted squarely to prevent damage to the threads.
Once you have replaced the insert you are ready to fit to your car and enjoy the smoother clutch operation this procedure gives.
Apologies for grammatical errors, spelling mistakes etc. and I look forward to your feedback.
Steve
I need to make an alteration to this post, which I will do at 13:00 today
My diagram is not 100% accurate and the alteration will show this change and makes the process easier.
Nice one... I will leave it here for a little while, then relocate it to "How To" in a day or so, once everyone has seen it... Thanks for your efforts :D
As mentioned he is a small amendment
After final confirmation with the guy who did this for me he confirmed that there is a step on the back end of the insert.
It is this step that has the interference fit, which makes life easy as the insert will drop into place through the bore without any problems, and just need a gentle tap to locate.
I don't see what the insert does. Bear in mind you can remove the CDV in its entirety, I can't see what adverse effect leaving the insert out would do. It looks like even with the piston removed the insert is acting as a venturi.
The insert forms part of the female fitting that the clutch pipe screws into, the taper on the insert sits agaisnt a matching taper on the male fitting.
The same fittings are used on brake pipes.
Aye I can see that, but the whole thing is made out of one piece of metal. Where would the clutch fluid leak to? Unless you're suggesting it would leak around the thread?
If you take the CDV out entirely, is there a similar type of female fitting on the bit of hose that goes into the other end?
Mine had more than a 'slight interference fit' to say the least, but if you split the washer with a thin screwdriver or simlar it is possible to get all the pieces out of the CDV with the insert in place.
The pipe that goes into that side of the CDV seals on the taper, the thread is for the fitting that pushes the pipe against the taper. It won't seal against
the thread.
If you take the CDV out the fittings each side are exactly the same and screw straight together. The CDV looks like an after thought that they simply added to an existing connection.
So can you just remove the valve without modding it?
Right, i know what i'm doing this weekend. well that and replacing my broken spring, i'm sure they're not made like they used to be :headbang:
I have modified the CDV myself and got it fitted but my mechanic told me that it would be more benificial to get a braided clutch hose fitted. The problem was that the end of the hose which will be the oposite to the CDV is a push-in fitting with a clip, a sort of quick release coupling so it was a bit hard to source. Eventually i found a place inthe U.S.A. that advertise on E-Bay and they had one in stock for the same price as a modified CDV. They were brilliant to deal with and delivery. By the way mine is 2.5l on a 53 plate. If you want I will send you details of the seller. I havn't fitted the new hose as yet as I am waiting for the next service to get that done the same time as the hydraulic change.
Here is a picture of the original clutch hose with the special fitting on the left and the CDV side on the right.
Z4 Rex, please put a link to the braided hose you purchased :)
Seems an easier step to just do away with it and fit a braided hose... out of interest, how long would it take to replace the hose? I'd pay an garage to do it, don't really have the access or tools anymore :(
Paul
Here is the link for the supplier. I have had a quick look on their website and I cannot see it there so I would get in touch with them and ask them to supply one. I paid $24 USD + $12 USD Shipping. The part number on the pack is BMWC-170. The description they used is "03-04 BMW Z4 Stainless Steel Clutch Line"
I dont think it would take more than 5min once the car is on the ramps cause all it needs is a clip removing and fitting pulled out one end then unscrew the CDV with hose still attached the other end. After that its just beeding the clutch. So therefore having a good guess no more than 30min. I am going to get mine done like I said next service which is due shortly cause the car will be up on ramps to drain the oil anyway. Once fitted then thats the most positive clutch action you can get cause there is no expansion of hoses or delays from the CDV. From what my mechanic told me he recomends braided hoses to all his customers with M-cars. Just a note here for anyone who hasn't got the special push in fitting but just a normal screw one, try these people as they are the first ones I contacted and the supplied me iwth the screw type fittings but did not have the special one then. They might have now? They are based in Silverstone and they are absoulutly brilliant and helpfull. I would recomend them for brake hoses definetly. The picture is of the hose I got from Bonehead Performance. :)
http://www.boneheadperformance.com/Merchant2/merchant.mvc
http://www.earls.co.uk/index.html
Just had my CDV removed. For anyone contemplating this - DO IT! It makes the gearchange/clutch action so much smoother, even just when pottering around town, you don't need to be thrashing it to notice the difference. I really can't understand why car testers don't comment on the delay when testing new BMWs.
I had my car in at Birds BMW last friday to have the CDV removed, but was told that they couldn't just 'remove' it because it needs something to replace it as it cannot simply be removed. I realise that others on here have had theirs taken out with no trouble at all - so was wondering if this is different for different models? ie pre and post face lift? and 2.5 -3.0?
ps it cost me £60 to be told this information. Not chuffed :(
The only problem I have heard with this is the connection could be a bit tight as there is 2" or so of section missing, a good reason to fit a modified one.
