Snow Foam Spray Bottle
- Vijay
Hi,
I currently use a Nilfisk C120 pressure washer. The snow foam spray bottle comes with, isn't the best.
Any recommendations...?
2007 Z4 3.0Si Coupe, Carbon Black, 53K on clock & counting...
Mineral White M240i
Mineral White M240i
Autobrite's one is very good - https://www.autobritedirect.co.uk/produ ... ifoam-kit/
- mr.tourette
I use the autobrite one too... but I've also found out if i use some snowfoam and car shampoo in the nilfisk jobbie I actually get a very decent foam and generally go down that route now as its usually less hassle as the bottle attaches to the end of the lance rather than the autobrite one having to connect to half the lance. Still think the whole thing is a bit of a gimmick to be quite honest but it does add a bit of fun to the proceedings
- mackharry
I use the PA lance https://www.cleanyourcar.co.uk/snow-foa ... s-fittings
With the autoglym polar blast, polar wash and polar seal, works really well but leaves a right mess on the drive
3.0 si sapphire black e85 facelift, individual leather New England black Silverstone grey, ZHP
Gone - Little 4pot e85 facelift ruby black metallic, oregon beige leather, ZHP
- Beedub
MTM HYdro..... expensive but very good quality item
- bradz
Try and get one with a conical shaped bottle helps it stand up on its own, Mine fell off the shelf and narrowly missed the car!
Z4M Coupe, E92 M3, E46 M3 Track car
- mr.tourette
Good idea that..does annoy me the top heaviness of them, another reason i use the nilfisk one
- Vijay
Thanks for the suggestions...
Mineral White M240i
Mineral White M240i
Online
I bought the MJJC snow foam cannon pro v2 from Aliexpress in the summer for my nilfisk. I have to admit, this thing is a beast, so glad I didn't just buy a cheap one. The nilfisk one that comes with the pressure washer is useless, its a great piece of kit that's very well made. I'd definitely recommend it.
I'm using this one as well but with a K5. Foam is amazing.
Kärcher FJ6 Foam Nozzle - Pressure Washer Accessory https://www.amazon.co.uk/dp/B00HH9QI1C/ ... UTF8&psc=1
This one is currently reduced on Amazon and a genuine karcher unit
E85 2.0i sport Monaco blue
Daily - VW T-roc
Daily - VW T-roc
Online
I assume you've got a Karcher pressure washer, I don't know your budget, so I presumed you wanted something in the same budget as the FJ6. I spotted this one, seems ok from the reviews. As long as the fittings are connected using ptfe? tape, I think I'd want something like this one.
Obviously, its your prerogative. So the best of luck whatever you decide.
https://www.amazon.co.uk/Adjustable-Can ... GJT6T?th=1
I personally would avoid this even if it’s on discount. I have one somewhere in my garage. Only used once then never touched it. It’s not much better than the solution spray function on the pressure washer.Bristolcot90 wrote: ↑Wed Jan 05, 2022 7:21 pm Kärcher FJ6 Foam Nozzle - Pressure Washer Accessory https://www.amazon.co.uk/dp/B00HH9QI1C/ ... UTF8&psc=1
This one, despite cheap, is still way better than the Karcher foam cannon. Again, got one in my garage and kept using it until switched to MJJCSpecial Kay wrote: ↑Wed Jan 05, 2022 8:59 pm I assume you've got a Karcher pressure washer, I don't know your budget, so I presumed you wanted something in the same budget as the FJ6. I spotted this one, seems ok from the reviews. As long as the fittings are connected using ptfe? tape, I think I'd want something like this one.
