Trim treatment
- GJ1
Trim treatment
Hello,
What are people currently using to treat the black exterior trims e.g. wing mirror triangles, lower grille, etc?
I've seen some references to gtechniq, is it the C4 one? Any other recommendations? Ideally looking for something that lasts a while (if there are any).
Can you/should you use these products on the rubber or are there different products to use for them?
07 Z4C 3.0si sport sapphire black
- Smartbear
Trim treatment
Turtle wax tyre dressing, it’s superb
e85 3.0si sold
OnlineMr Tidy
Trim treatment
I used Gtechniq C4 on the door mirror triangles on my previous E86 and it worked really well. But it isn't cheap!
I would have tried the Turtle Wax but at the time I couldn't find any.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- flimper
Trim treatment
I'd be wary of Gtechniq C4. I bought it, used it once, put it away and when I came to use it again it had crystallised and I had to bin it. Very expensive
Piano black & black extended leather. Power mirrors, tinted glass, PDC, Prof hi-fi, CD, retro-fit cruise
- GJ1
Trim treatment
Thanks, this one?
https://www.toolstation.com/turtle-wax- ... gK3avD_BwE
I've seen back to black mentioned as well but not sure what brand.
Any other recommendations out there before I pay a visit to toolstation!
Trim treatment
I have been looking into this today. From the looks of it you can use it on the rubber on the windows too. It lasts for around 2 years rather than 4/5 washes like some other stuff. Has nothing but great reviews on the detailing forums but you are looking at 20-22 quid for it.
You are supposed to use it within 3 months of opening- perhaps that's why it crystallised?
- flimper
Trim treatment
Didn't know about the 3 months, that would explain it. Only suitable if you attend to your trim each month then I suppose
Trim treatment
Which I doubt you will ever do if it's lasts for circa 24.
It's a one hit wonder for 20 quid. I guess you do your car, the Mrs car and then crack on with some of the plastics in the engine bar to use the rest of it up.
It's on my list but I need to purchase 51317017021 (the windscreen surround ) 1st as it will stand out like an eyesore with everything else restored.
- flimper
Trim treatment
Yes, I for one will not buy it again, I wasn't overly impressed and certainly didn't last as long as they state. Be interested to know how much the windscreen scuttle costs and how easy it is to fit as mine seen better days
Trim treatment
That's a shame- I thought it was the answer to all my prayers (I was debating C4 or slowly replacing the plastic).
£30-40 quid depending on who you go with. I would buy OEM for the sake of a fiver or so.
https://www.youtube.com/watch?v=Nh2R0wm ... ouchGarage
Doesn't look to hard of a job.
Trim treatment
Maybe the surface wasn't prepped properly before applying thereby not allowing good adhesion? I know detailers say to use something to wipe the panels down (IPA I think) before applying the Gtecnics stuff.
Another longer lasting trim rejuvenator with a good reputation is Gyeon Trim, again not cheap but supposed to last a long time if applied correctly. Most normal trim dressing only last a few weeks or days even.
Trim treatment
Sorry wrong part.
Windscreen Scuttle or as BMW call it "Cover Windshield" item 51717043619 is.... wait for it... circa £155....
I changed one on my old 182 about 5 years ago and slipped and cracked my windscreen. Expensive day that when I had no windscreen cover on my insurance... Bit of a ball ache getting the window wipers apart to be able to fit the new part.
- flimper
Trim treatment
Thought it might be that high, only slight cosmetic damage so will probably leavemgrlane wrote: ↑Wed Oct 14, 2020 8:50 amSorry wrong part.
- flimper
Trim treatment
Very possibly, I know the trim was spotlessly clean but I didn't go as far as IPASilverstar wrote: ↑Wed Oct 14, 2020 8:40 amMaybe the surface wasn't prepped properly before applying thereby not allowing good adhesion? I know detailers say to use something to wipe the panels down (IPA I think) before applying the Gtecnics stuff.
Trim treatment
I use 303 aerospace protectant on the exterior trim as it’s supposed to have good UV resistance. I’m not sure it’s a trim rejuvenator as such, but it does darken the plastics and should offer some protection against the elements.
RUBYIMOLACARBON
