Kind of a big problem here.
Every time I make or receive a call regardless of if I answer it or not, the car gets stuck on phone mode. If I change the volume it says phone.
I am then unable to select a radio channel or music. Just silence.
I am connected via Apple car play.
I have tried disconnecting the phone and it then Just says Audi source unavailable.
The only way to get radio back is to stop the car, switch it off, open a door and start up again.
Any ideas? I’m running the latest software versions.
No radio or music after phone call.
Ok so I managed to solve this by resetting I drive. I held the volume button down until it reset. This seems to have solved the problem for now. ![Wink ;)](./images/smilies/wink.gif)
So this problem has returned. Solved again with reset.
Anyone else have this issue?
how do you have your phone connected?
I use my phone through apple carplay, and i dont have this problem.
I use apple carplay too. I think I have figured out what causes this. If i enter the car with a call already running and it switches to the car, that’s when it triggers the problem and I have to reset. Problem hasn’t occurred since so I’ll keep and eye on it.
Also try just restarting your iphone for me its usually the phone causing the problems ![Smile :)](./images/smilies/original.gif)
