Getting really frustrated.
I replaced secondary Air Pump only to find that the relay is bad. thats not the frustrating part, after tearing apart the glove box (because thats were I was told that I could find the relay only to not find it there, it also isnt in the relay box that in under the hood drivers side. Can anyone help find the location of the elusive relay?
2003 Z4 secondary air relay location
- enuff_zed
Good morning and welcome to the forum.
According to Newtis the relay is on the rear of the fuse box:
- enuff_zed
And here's the wiring diagram.
I assume you've already checked out Fuses 33 and 56?
- Capture.PNG (27.61 KiB) Viewed 952 times
I never thought to look on yhe back of the fuse box. That's going to be a trick to get there. Thank you for this information. Will post results later today.
- colb
Couple of screws at the top and the whole board will drop down into the footwell then you can get to the rear and the relays plugged in the back. There is enough slack on the cables to allow access.
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1999 1.8 Z3
2003 2.5 Z4
Good afternoon, and thank you for the information provided to help me locate the relay. I would not have thought to locate it on the back of the fuse box,
New relay is in place and now the pump is working properly.
Again, thank you for giving me the location.
GY
GY
- enuff_zed
Great news. Glad the forum has been able to help and hope you stick aroundGerald Yoquelet wrote: ↑Sun Nov 27, 2022 9:00 pm Good afternoon, and thank you for the information provided to help me locate the relay. I would not have thought to locate it on the back of the fuse box,
GY
