12v Jump Starter Packs?
- inkey$
What are people using and would recommend for 3 litre petrol cars and below?
Looking for something that is reliable, compact, not too heavy, usable USB ports etc. Seem to be a lot of choice out there.
This NOCO GB20 is in the lead so far...
https://www.amazon.co.uk/NOCO-GB20-Ultr ... hdGY&psc=1
Previously: Z3R 2.8 • E46 330i • Z4R 3.0 • Z4///MC • E90 335i • Z4///MR • Z3///MC 'Breadvan' • Z3R 2.8 • E30 325i R • Z4C • Z4R 3.0
I have that exact one Inks, works very well, small, light-ish, the leads are very thick and robust, no gripes with it.inkey$ wrote: ↑Wed May 10, 2023 5:18 pm What are people using and would recommend for 3 litre petrol cars and below?
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- inkey$
A review good enough for me, John. Orderedjohn-e89 wrote: ↑Wed May 10, 2023 5:30 pmI have that exact one Inks, works very well, small, light-ish, the leads are very thick and robust, no gripes with it.inkey$ wrote: ↑Wed May 10, 2023 5:18 pm What are people using and would recommend for 3 litre petrol cars and below?
Highly doubt you'll be anything but very pleased with it Inks, the whole thing is very well made with the ports and leads all superb quality.inkey$ wrote: ↑Wed May 10, 2023 5:32 pmA review good enough for me, John. Orderedjohn-e89 wrote: ↑Wed May 10, 2023 5:30 pmI have that exact one Inks, works very well, small, light-ish, the leads are very thick and robust, no gripes with it.inkey$ wrote: ↑Wed May 10, 2023 5:18 pm What are people using and would recommend for 3 litre petrol cars and below?
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- N4LLY
- inkey$
- pvr
Bought it as well. It was £75 business only price, is that what you paid or is that Amazon - you-think-you-get-a-deal thing
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- inkey$
I paid £89 delivered before 1pm tomorrow. You got filtered in the right way I think.
- DonDon
Just seen this thread, an hour after my Grepro arrived from Amazon (£46). Obviously don't know if it's any good yet, but it looks the part.
2013 E89 28i auto
- MikeyH
How does this work on an E85? It can't be used on the actual battery can it, so it is connected to the in engine compartment connectors and if so will the wires reach? Sorry if this me sound stupid
- TitanTim
Would be interested to know this too, I know when charging the battery if you have connectors in the engine compartment then you should always use these and not connect directly to the battery as it can potentially cause damage or the battery doesn't get charged correctly, might be different with jump starters
Tim.
- MikeyH
Someone on here will knowTitanTim wrote: ↑Sun Jun 25, 2023 11:16 amWould be interested to know this too, I know when charging the battery if you have connectors in the engine compartment then you should always use these and not connect directly to the battery as it can potentially cause damage or the battery doesn't get charged correctly, might be different with jump starters
Tim.
Positive to the jump terminal on the firewall as you know, but you're correct that you can't reach the cars earth stub so when I've used it I've clamped the earth to the strut brace nuts or somewhere down by the gearbox. And yes, don't connect to the battery, always use the positive connector in the engine bay.MikeyH wrote: ↑Sun Jun 25, 2023 11:18 amSomeone on here will knowTitanTim wrote: ↑Sun Jun 25, 2023 11:16 amWould be interested to know this too, I know when charging the battery if you have connectors in the engine compartment then you should always use these and not connect directly to the battery as it can potentially cause damage or the battery doesn't get charged correctly, might be different with jump starters
Tim.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- TitanTim
Thanks Johnjohn-e89 wrote: ↑Sun Jun 25, 2023 11:56 amPositive to the jump terminal on the firewall as you know, but you're correct that you can't reach the cars earth stub so when I've used it I've clamped the earth to the strut brace nuts or somewhere down by the gearbox. And yes, don't connect to the battery, always use the positive connector in the engine bay.MikeyH wrote: ↑Sun Jun 25, 2023 11:18 amSomeone on here will knowTitanTim wrote: ↑Sun Jun 25, 2023 11:16 am Would be interested to know this too, I know when charging the battery if you have connectors in the engine compartment then you should always use these and not connect directly to the battery as it can potentially cause damage or the battery doesn't get charged correctly, might be different with jump starters
Tim.
Tim.
Have you still got that blue 135i Tim....? No reason other than idle nosy curiosity....TitanTim wrote: ↑Sun Jun 25, 2023 12:39 pmThanks Johnjohn-e89 wrote: ↑Sun Jun 25, 2023 11:56 amPositive to the jump terminal on the firewall as you know, but you're correct that you can't reach the cars earth stub so when I've used it I've clamped the earth to the strut brace nuts or somewhere down by the gearbox. And yes, don't connect to the battery, always use the positive connector in the engine bay.
Tim.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
