Wireless charging options.
Discussing the current generation Z4
mrwkuk
Post by mrwkuk » Fri Jun 23, 2023 7:47 pm
My car didnt come with the wireless charger, so I am looking at options to retrofit. I know i could get the legit one, but I suspect thats going to be quite spendy so an interim solution would be good.
Looking at something like this: https://www.amazon.co.uk/Wireless-Charg ... 0B1JG562P/
Has anyone used one of these? do they fit? or got a better suggestion?
I know some people have had heat issues due to the low airflow in that location. I think that was mostly iphones tho. Ive not had any problems with my pixel 7 getting hot on a wireless charger (altho ive not done it for an extended drive).
srhutch
Moderator
Moderator
Post by srhutch » Fri Jun 23, 2023 10:00 pm
I have one of those, tried it in my F11. Issue I had was it interfered with DAB reception and mobile signal.
I just plug into to usb now and charge that way.
mrwkuk
Post by mrwkuk » Sat Jun 24, 2023 12:23 am
srhutch wrote: Fri Jun 23, 2023 10:00 pm it interfered with DAB reception and mobile signal
Interesting...
mrwkuk
Post by mrwkuk » Thu Jun 29, 2023 8:39 pm
So i bought one anyway, because it was cheap enough, and seems to work fine. No DAB issues, at least when parked.
Remains to be seen if the mobile reception is impacted significantly but it looked ok.
The only real down side is cable routing. I might look at doing something about that later.
ori
Post by ori » Tue Jul 04, 2023 1:34 pm
So I ordered this from
Amazon and if you remove the tray that is currently in there it sits perfectly.
Phone charges and no overheating issues like with oem bmw wireless charging.
Good solution.
