Roof repairs
Roof repairs
Hi,
Read a few posts now and viewed a number of U-tube videos on roof problems.
Number one issue seems to be broken wires.
Can someone identify replacement wire used for repairs.
What gauge etc should be used to cover required power but be flexible to avoid fatigue breaks when open and closing multiple times.
Also suppliers to place orders with if possible.
Jim.
Jim.
- Marcoose
Roof repairs
Roof repairs ? Go with Spanish tiles. Very pretty. What’s the problem with your roof ?
2016 35is, monoballs, camber plates, KWV3, PS4S, xHP, MHD, LFB pedal, flat bottom wheel, red indicators, black headlamps
Roof repairs
Microswitch rear-end module closed right.
Error A692.
Have ordered replacement switches but thinking on replacing wiring from switch connectors back down to near the controller connector in the boot.
One of the utube videos suggested all harnesses should be replaced every 10 years. Mine is a 2011 model thus looking at what is involved.
Fix all at same time or multiple breaks over time and possibly out in the sticks when failure occurs.
Error A692.
- RobbiZ4
Roof repairs
Several answers in this HowTo:
E89: Retractable Hardtop (roof) Maintenance (and additional) tasks
viewtopic.php?t=130932
0.25mm² LiFY from TrueComponents in the correct colour from CONRAD is my 1st choice.
Don't touch the two switches in the rear roof shell. It's difficult to replace, but not required at all.
Pardon, je suis Allemand
E89 Roof Maintenance
Y3 Roof Diagnostic System
viewtopic.php?f=23&t=129048
Roof repairs
I just used some mains flex, let's see that break.
Roof repairs
Thanks again for the feedback.
Lot of info in the file to digest.
Can now order cable if required.
Roof repairs
Hi all,
For clarification and to make sure I’m not off working on the wrong switch, can someone confirm location of part that needs to be changed to fix error code ..
Error A692.
And a link to any video showing a how to repair on said switch.
Ta.
Error A692.
Ta.
- RobbiZ4
Roof repairs
javis20 wrote: ↑Mon Dec 04, 2023 5:39 pm Easy job, here is my video.
https://youtu.be/qcwZC1uah_o?si=Idis1z4coQSmfH6u
Roof repairs
Thanks again.
After I replace both side switches should I also replace the wires back to the multipin connector?
Just asking as these wires don't appear to move as far as the roof module ones and may not be near breaking point?
Ta.
Ta.
- RobbiZ4
Roof repairs
No.
With these wires there will never be a problem.
