Battery booster
Battery booster
I have a 2015 E89. Looking for a battery jump starter that you’ve used and tested in an E89.
I am UK based so want one that I can easily get hold of here in the UK. I’ve never owned one before but people talk about the Noco’s - either love them or hate them, though they seem to be more expensive. A recovery guy started an old E36 of mine a few days ago and wouldn’t touch a lightweight booster - but I want for very occasional use hopefully!
Thanks, Tony
Thanks, Tony
OnlineMr Tidy
Battery booster
I bought a Tacklife T6 on Amazon in 2019 and it started my E86M Coupe easily enough in 2020 when the battery had died.
Something like that should be fine for very occasional use, but probably not for a recovery guy!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- Marcoose
Battery booster
If this sells in the U.K., it’s a great tender, charger and starter.
Schumacher SC1281 100 Amp 30 Amp... https://www.amazon.com/dp/B07BLLRM8R?re ... b_ap_share
2016 35is, monoballs, camber plates, KWV3, PS4S, xHP, MHD, LFB pedal, flat bottom wheel, red indicators, black headlamps
- B21
Battery booster
If your having to use a booster on an e89 for starting then you’re probably not tackling the issue ..better to use a maintenance charger and keep the battery state healthy..
Lots of issues relating to poor battery health on E89s
IMHO
IMHO
- RobbiZ4
Battery booster
Just a fresh new AGM 70Ah battery should do the trick.
Pardon, je suis Allemand
E89 Roof Maintenance
viewtopic.php?t=130932
Y3 Roof Diagnostic System
viewtopic.php?f=23&t=129048
Battery booster
Cables too short!
I will be buying one of these booster packs. The only thing is that the cables aren't long enough to go from the positive to negative points in the engine bay (I measured this as 83cm in the engine). Is there another grounding point nearer to the positive point in the engine bay - be aware that I am very not-electrically aware lol
- Chippie
Battery booster
Don’t know which booster you are buying, if the positive and negative are joined together with only a short amount of separation at the ends then you can pull them apart to increase the distance between the ends, hope that makes sense
- enuff_zed
Battery booster
Had the same problem with my Ctek. It reached but only just, even with the wires separated.tonyg wrote: ↑Tue Dec 05, 2023 11:09 am Cables too short!
On the left side suspension tower, about half way down into the bay there is a multiple earth point. The mounting stud for that leaves plenty of thread to clip an earth cable on to.
Online
Battery booster
Or anywhere metal that hasn't got paint on it. On a DC powered car, the metal body/ chassis IS the earth. All of it!enuff_zed wrote: ↑Tue Dec 05, 2023 12:50 pm Had the same problem with my Ctek. It reached but only just, even with the wires separated.
Suspension top mount bolts are good, as they are easy to get to and on both sides. Although not great if you need to shut the bonnet with the charger attached, granted!
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
Online
Battery booster
Allowing your battery to discharge enough that you NEED a jump pack is not good. It will damage the battery, so it won't charge properly then you will have all sorts of electrical faults appear, which will be battery related. The E89 does not like a compromised battery, it is very specific about that!tonyg wrote: ↑Tue Dec 05, 2023 11:09 am Cables too short!
F31 320i. Good car.
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
Battery booster
Quote for new battery incl registration from BMW main dealer £323. Is there somewhere recommended cheaper, I’d like it all fitted and registered. Either a chain store or somewhere near Hertford. Thanks.
- B21
Battery booster
Halfords ,Kwik Fit etc
Confirm they will do registration before booking /paying
Exide, Yuasa, Varta, Bosch etc are tier 1 suppliers
Battery booster
My go to jump pack is Noco GB40. Only use it as LAST option. I have only used it once on the 2014 Z4 - driving home after purchase a few months ago. Also great for charging other devices and running laptop on the road. Would suggest purchasing the fitted case to match.
https://no.co/gb40
https://no.co/gb40
