Heater controls STOP working after battery light came on dash
Hi , so just been out and after I turned engine off the Battery light appeared on the dash and then went off after a minute or so but then I noticed the heater control lights all went out and the fan is dead so I restarted the engine and even with engine running there’s absolutely no lights or fan working on control panel. To me this points to a battery issue. Drove home had a look at battery in the back and the health indicator is still green but I do plan on charging battery first thing tomorrow. Hopefully the fan and control lights will all work once battery is back up to full voltage. Is this normal ( new to z4 ownership) thank you for any help/ advice
- B21
Check the age of the battery..battery health is critical to E89s..all sorts of s**t happens with a poor battery condition..
Simple battery condition indicator not a valid indicator on E89s..
Charge battery off car or via battery post in the engine bay.
A decent BMW specific code reader is an essential tool for any E89 owner..
Good luck..
Good luck..
