Hi all … am I correct in thinking that the small LED side lights I fitted the other day have brought the dash wanting light on ? And if so , anybody know of a set that don’t ?
Thank you
Dash warning light for bulb out
- IMG_9286.jpeg (125.53 KiB) Viewed 138 times
Basically you need canbus friendly ones.
The resistance on some leds will put the bulb warning on.
2009 09 Carbon Black Cinnamon E86
- enuff_zed
Using scanner 1.4 I can see a large table showing all the lights and tick boxes for various checks on them.
Usually I find the numberplate lights are unticked and therefore not checked.
If you found someone with that software they should be able to remove the check on the sidelight bulbs too.
Ah ok .. does sound like the side light LED’s then . If I remove them and put the standard ones back in , will the dash light go out ?enuff_zed wrote: ↑Sat Apr 06, 2024 2:49 pm Using scanner 1.4 I can see a large table showing all the lights and tick boxes for various checks on them.
- enuff_zed
Yes it should do.Bodyboarder wrote: ↑Sat Apr 06, 2024 3:12 pmAh ok .. does sound like the side light LED’s then . If I remove them and put the standard ones back in , will the dash light go out ?enuff_zed wrote: ↑Sat Apr 06, 2024 2:49 pm Using scanner 1.4 I can see a large table showing all the lights and tick boxes for various checks on them.
Thank you … yep put the old ones back in and dash light out
- enuff_zed
These ones worked ok for me.Bodyboarder wrote: ↑Sat Apr 06, 2024 4:31 pm Thank you … yep put the old ones back in and dash light out
https://www.ebay.co.uk/itm/165634647247
