Howdy, ya'll. (A bit of southern charm.)
I've removed the MHD and xHP maps for the California emission tests. And reinstalled after passing. Previously, the MHD was version 9, and xHP was with an older version of the iOS app. Since MHD has version 10 map, I've used it. With xHP, there's no choice but to use the current version of the app.
I haven't taken the car for a spirited drive yet. But on short errands:
1. The car is noticeably (and annoyingly) more noisy on upshifts and downshifts (burble is off)
2. There's more (cat?) rattle
3. Cold starts are noisy (with option on as before)
4. From cold starts, the car wants to stall within 20 metres, but it corrects itself
5. I cannot make the car creep in gear (as before)
Any similar experiences ? And fixes ?
Thanks.
MHD and xHP since last updates
- Marcoose
2016 35is, monoballs, camber plates, KWV3, PS4S, xHP, MHD, LFB pedal, flat bottom wheel, red indicators, black headlamps
OnlineB21
What versions of each have you flashed ?
MHD stage 1 etc xHP stage 1,2,3 ?
- Marcoose
MHD is Stage 1. xHP is a bespoke map by a fellow forum member. Both worked great before the uninstall.
OnlineB21
Looks like somethings got reset / changed in the restore with new variants..looks like it wil need to be set up from scratch..
- Marcoose
Peter, so in your experience, with MHD v10 map you don't experience any of my symptoms ? Or with the new iOS version of xHP ? And you're suggesting to revert everything again to stock and re-install ?
OnlineB21
I used v9 stage 1+ 2+ and v10 stage 1+ and 2+ with no issues after my first coil failure..have you checked the various option boxes ?
XHP stage 2 on v1.3 I use with some personal tweaks to gearbox maps all very nice
- Marcoose
Yes, spent hours double-checking all boxes to make sure it wasn't user error.
- Marcoose
Update: Indeed, the culprit was the new app version, specifically small details with boxes to check.
If you were running a bespoke map installed with an app from circa 2021, and had to uninstall and later re-install with today's app, you need to do the following:
- On the very first screen, tap '... More', tap Settings, and uncheck 'Custom Map PST-C'.
- If you're like me that likes 'creep', in Flash Setting tap Edit, scroll to Comfort/Economy, tap Edit next to Configure Creep, tap Setting Activated, tap Creep Enabled, tap Save. (I didn't have to do that before.)
I've only driven around the block. So far two of the old settings are back. I'll give it a push this weekend to make sure other preferences are back.
Whilst the xHP folk deserve praise for fixing the problem, truth be told, communicating with them was at times frustrating. But all's well that ends well.
