PDF Owner's Manuals, Retrofit Instructions and Links
PawnSacrifice
Veteran
 South Oxfordshire
I was looking for PDF retrofit instructions a while ago and a found a few other Z4 documents. I then expanded my search and found more documents available from numerous sites online, for public download. I've collected them in one place, links below. Some of the reference documentation is very useful for DIY mods.
I hope the links are reliable - if not I may need to move to another host (currently on DropBox). Also, not currently sure how it will handle concurrent connections / downloads.
Below this section I want to add links to my mods - running out of space in my signature! Please feel free to do likewise - prefer to keep it to links on here though.
:!: Some of the owner's manuals are quite large files and can take a while to download. For some reason the E89 manual seems to pause for quite a while on Chrome, works better on IE and Safari (Mac).
:!: The manuals may be EU/US specific, while most of the functions will be the same there may be the odd discrepancy.
Starting at the beginning:
Owner's Manuals
2003 Owner's Manual
2004 Owner's Manual
2005 Owner's Manual
2006 Roadster Owner's Manual
2006 Supplementary Owner’s Manual for BMW Z4 M Roadster/ Z4 M Coupe
2006 Supplementary Owner's Manual for BMW Z4 M Roadster
2007 Supplementary Owner's Manual for BMW Z4 M Roadster/ Z4 M Coupe
2010 Owner's Manual
BMW USA Information
Seems BMW USA beat me to it. Looking for a few missing manuals I found this page on the USA site...
Owner's Manuals
There is some other great info on there too. Select the year and car and in addition to the manual there are some handy How To videos.
Specifications - many thanks to Wondermike :thumbsup:
UK Z4 pre- and post-facelift specification
BMW Retrofit Instructions
Active seat ventilation system retrofit kit BMW Z4 (E85)
Aerodynamic Package Retrofit Kit LHD and RHD BMW Z4 (E85)
Illuminated Door Sill Strips Retrofit BMW Z4 (E85)
TV Function retrofit kit BMW Z4 (E85)
Xenon Light Retrofit with Automatic Headlight Adjustment Control BMW Z4 (E85)
Park Distance Control (PDC) Rear Retrofit BMW Z4 (E85)
Cruise Control Retrofit BMW Z4 Roadster (E85 / BMW Z4 Coupe (E86)
Wind deflector retrofit BMW Z4 (E85)
Retrofit kit - Dome strut BMW Z4 (E85)
Multi-functional steering wheel retrofit kit BMW Z4 (E85)
Navigation system (not including TV function) BMW Z4 E85
Alpine CD changer installation instructions BMW Z4 E85
Hardtop Retrofit Kit RHD and LHD BMW Z4 E85
Reference Documentation
BMW E85 Complete Vehicle
BMW E85 Chassis Dynamics
BMW E85 Driver Information
BMW E85 Heating / Air Conditioning System
TIS Links
BMW TIS Online Repair Manuals (Thanks, Peddy for this one)
BMW WDS - Wiring Diagram System
Third Party
Lumenux CCFL Install Instructions
Dension Gateway 300 Installation Instructions
Dension Gateway 100/300/500 User Guide
gookah said:
not opening for me.....
Thanks. Which one? I've been through this morning and tested them all on my work PC, some are slow due to the file size, some also don't like Chrome so much.
I also spot tested a few on my BlackBerry and they seemed to load okay.
If there was anything that you wanted in particular that won't load, DM me and I'll send you the file by email. Files up to a little over 8MB.
All work for me. Incredibly useful resources Matt, many thanks for posting all in one location :thumbsup:
Brilliant!!!
Page now bookmarked for future reference
Thanks for taking the time to put this together :thumbsup: :thumbsup:
may be because I am using chrome, just blank white screens for over 5 minutes
2004 owners manual
2006 Supplementary Owner's Manual for BMW Z4 M Roadster/Z4 M Coupe
TIS are OK, as are your links, just seems to be dropbox ones
2004 owners manual
Ok now. I copied links to IE8 and opened them from there,
Great thanks.
Brilliant. Thanks for all that info, I've been searching for days for the 05 owners manual. I didn't get one when I got the car! Maybe now I won't have to post inane questions on the forum.
Great thanks.
Yeah, is odd - normally if something isn't going to work it will be IE! Watching the download progress Chrome seems to struggle with the final handoff. Oddness.
imp75, excellent - means it was a worthwhile execrise :thumbsup:
:!: One thing to note, I think some of these may be US manuals, need to go through and check. The main functions should be similar though.
What do you need Taz? I'll have a look for you, but I'm not sure it's something you can download though.
If you can't see any of the images and you're on a Windows machine try installing the Adobe SVG plugin.
EDIT: See you've tried that already - PM replied.
If you search for N9. Fuse R 47 should be the switched supply.
Plug connector overview
Number X-pin, colour Description
X13342 1-pin Cable shoe Radio
X18126 16-pin, black Plug connector Radio
X13598 12-pin, grey Plug connector Radio
X13321 12-pin, natural Plug connector Radio
X18805 8-pin, black Plug connector Radio
Assignments at cable shoe X13342
Pin Type Description / Signal type Connection /
Measuring notes
1 E Signal, aerial reception Aerial amplifier or aerial diversity
Pin assignments at plug connector X18126
Measuring notes
1 Not used
2 Not used
3 Not used
4 Not used
5 Not used
6 Not used
7 Not used
8 Not used
9 E/A K-bus signal K-bus connector
10 E Telephone mute circuit Cellular telephone
11 E Signal Telephone on Cellular telephone
12 M Ground Ground point
13 E Aerial switching signal Aerial amplifier or aerial diversity
14 E Activation, left bi-xenon headlight Light switch cluster
15 E Terminal 30 Fuse F50
16 E Terminal R Fuse F47
Pin assignments at plug connector X13598
Measuring notes
1 Not used
2 Not used
3 Not used
4 Not used
5 A Navigation signal Positive activation Navigation system or Video module
6 E Signal, telephone AF + Cellular telephone
7 Not used
8 Not used
9 Not used
10 Not used
11 A Navigation signal Negative activation Navigation system or Video module
12 E Signal, terminal 50 via vehicle immoblizer Cellular telephone
Pin assignments at plug connector X13321
Measuring notes
1 Not used
2 E Signal, CD changer AF - CD changer
3 Not used
4 Not used
5 Not used
6 Not used
7 Not used
8 E Signal, CD changer AF +, left CD changer
9 E Signal, CD changer AF +, right CD changer
10 Not used
11 Not used
12 Not used
Pin assignments at plug connector X18805
Measuring notes
1 A Signal, AF radio, rear right + Amplifier
2 A Signal, AF radio, front right + Amplifier or Speaker
3 A Signal, terminal 50 via vehicle immoblizer Amplifier or Speaker
4 A Signal, AF radio, rear left + Amplifier or Speaker
5 A Signal, AF radio, rear right - Amplifier or Speaker
6 A Signal, AF radio, front right - Amplifier or Speaker
7 A Signal, AF radio, front left - Amplifier or Speaker
8 A Signal, AF radio, rear left - Amplifier or Speaker
Hope that helps. I'm sure you will, but test to make sure the connections are what they should be.
