Rear tyres wear quicker than fronts?
- johnbmwboy
Hi All,
I've got Conti RFT's on the front that have a lot more tread (7mm) than the Bridgestone RFT's on the rear (4mm).
I'm going to swap them over because I presume the rears wear quicker than the fronts? Am I right?
Cheers,
John
Cheers,
John
Re: Rear tyres wear quicker than fronts?
Rears do wear faster as the car is RWD. Depending upon the size of your wheels, you may not be able to swap them over as the rear wheels may be wider than the fronts.
- ubicomp
Tires on the drive wheels always wear faster than the non-drive wheels.johnbmwboy wrote:I'm going to swap them over because I presume the rears wear quicker than the fronts? Am I right?
2007 ///M Roadster
Personally don't see the point in doing that especially if running summer tyres all years round. The wear characteristics are also different between front and back. Just put new tyres on the rear then next time they'll probably all need replacing arounnd the same time. SOd paying for someone to swap the old tyres over to the rear unless of course you can just swap the wheels round if they're the same size . Personally I wouldn't do it though.
As Daffy has said you mgiht find the tyres are different sizes anyway
Current 2011 X1 2.0d xDrive
2006 Z4 M Coupe Interlagos with Light Sepang interior - GONE 08/2012 - PY56 GH* - where now?
2006 Z4 Si Coupe - Montego blue - GONE approx 05/2009 - WJ56 YU* - where now?
- johnbmwboy
Thanks all.
I've got stock 245x45x17 all round.
I want to replace my run flats all at once, so think I'll swap the good un's front to back. Do a few burn out's with my 2.0 and they'll all wear out at once
Already got the compressor and cans of tyre goop at the ready.
Cheers,
John
Cheers,
John
- Ewazix
Not abad idea to swap anyway, as a general rule you should put your best tyres on the rear irrispective of it being front or rear drive, but more so on a sports RWD.If the front lets go first in a bend the results are likely to be understeer, if the rears let go it's hedge-backwards time unless you or the DSC are on the ball.
2018 Cooper S Countryman
Fiesta Ecoboost
Fiesta Ecoboost
- RichardG
Standard tyre size on the 103's is 225x45x17, think you better double check or is it a typo.johnbmwboy wrote:Thanks all.
Cheers,
John
04 2.5 SE, Alpine iDA X-305, Eibach's, M Tri-Colour MFSW, CF Roundells, LeatherZ Armrest, De-Gingered, 19" VMR V710's, Aero Skirts, Fr & R M Bumpers, Quad Exhaust and NO Stubby
- johnbmwboy
You're right, it's 225 not 245. Thanks Richard.RichardG wrote:Standard tyre size on the 103's is 225x45x17, think you better double check or is it a typo.johnbmwboy wrote:Thanks all.
Cheers,
John
- johnbmwboy
Crikey, I didn't think of that. Thanks.Ewazix wrote:Not abad idea to swap anyway, as a general rule you should put your best tyres on the rear irrispective of it being front or rear drive, but more so on a sports RWD.If the front lets go first in a bend the results are likely to be understeer, if the rears let go it's hedge-backwards time unless you or the DSC are on the ball.
- powerontap
If you have DTC and turn it off, you can expect 50-75% faster wear...I've experienced it myself!
Go Topless
If you have 4mm tread depth in the middle of the tire I'll bet you don't have anything near that on the inside edge. The negative camber of the rear suspension wears the tires at a very uneven rate.
- nicko
I'm guessing you mean DSC, rather than DTCpowerontap wrote:If you have DTC and turn it off, you can expect 50-75% faster wear...I've experienced it myself!
56 Z4 Coupe 3.0si Sport, Montego Blue, Champagne Leather, 135Ms, ZHP
- powerontap
Pressing the DSC once disables traction control only, not the stability control.nicko wrote:I'm guessing you mean DSC, rather than DTCpowerontap wrote:If you have DTC and turn it off, you can expect 50-75% faster wear...I've experienced it myself!
Go Topless
- nicko
Is your manual different to mine?powerontap wrote:Pressing the DSC once disables traction control only, not the stability control.
Pressing DSC button once enables DTC
DTC is traction control
you can have
DSC (traction control and stability control)
or
DSC+DTC (more traction control and less stability control)
or
nothing [DSC off] (no traction control and no stability control)
- a11y
Agree with this 100%. I always argue with my father-in-law (who's a car trader) about this: he says put best tyres on the front, I say best tyres on the rear. Unless you're a driving god, understeer is a far safer thing to deal with than oversteer - on the public roads at least.Ewazix wrote:Not abad idea to swap anyway, as a general rule you should put your best tyres on the rear irrispective of it being front or rear drive, but more so on a sports RWD.If the front lets go first in a bend the results are likely to be understeer, if the rears let go it's hedge-backwards time unless you or the DSC are on the ball.
