Trigger Angel Eyes to Come on/off When Unlock/Lock
sam1832
Post by sam1832 » Wed Aug 08, 2012 11:48 pm
So this a DIY i wrote a while back for my E46, that i have adpated slightly,
Unfortunatly i dont have any pics of it, as i done this in a E46
SO here goes, hopefully it helps some people out
This guide is for when the angel eyes only have one wire to pick up a +ive feed from and will work weather they eyes are running as DRL's or off of the side/dipped head lights.
This will let you AE come on with the footwell lights and go off when they go off
So for this you will need:
  • A few meters of thin wire
  • 1 scotch lock
  • 4 diode's
  • heat shrink
And a few tools
  • Philps screw driver
  • Side cutters
  • cimp tool and crimps
  • stanley knife
So after installing your angel eyes, you need to run a wire from the inside of your car to the engine bay, this will be your new trigger wire.
I then ran my new trigger wire from my side lights into the engine bay you need to split the wire in to two. I used a straight connector crimp with one wire in one side and two on the other. So that you can run one to your left head light and the other to your right headlight, once you have your wires run to your head lights cable tie it all in place.
You will need a diode to prevent your angel eyes from turning your interior lights on when you dont want them on, and anouther diode to stop you interior lights from turning on your side lights
You will have to excuse my shoddy wireing diagram in paint lol but it does the job,
So the Key:
yellow box- interior light
Yellow Circles - angel eyes
red - +ive
black - -ive
green - New trigger wire
Pink - Main trigger wire (that comes from either side lights or switch live)
Blue - wire connecting angel eyes together
dodge black triange - Diode
So the as you can see from the diagram a diode needs to be placed on your new trigger wire faceing your angel eyes
Also anouther diode needs to be put into your main trigger wire, to stop your interior lights lighting your side lights up
REMEMBER DIODES HAVE A POLARITY AND WILL NOT WORK BACKWARDS
Next we are going to make the part with the diodes in:
Now you need to cut off a section of your thing wire, your gonna need about 8inches
Cut it in half, then cut it in to four 1 inch lengths and then strip all the ends of the wire
take a straight connector crimp and push two 1 inch lengths into the same end and crimp
Now on the other end of each of these wires you need to solder the -ive leg of your diode
On the other side of you diode, the +ive you need to solder the other two one inch wire you cut, then using two more straight connector crimps connect these to the ends
So you now have a Y shape
Put some heat shrink over the diodes
You will need to make this again for the other side, So you should have two Y shapes
So back on the car now you need to connect you Y in looking at one side at a time, Im gonna assume most people have CCFL's and are using there side lights to turn them off and on, but if you are running them as DRL's or from the dipped beams this is fine.
Starting on the drivers side:
So you have a wire that comes from the +ive of your side lights to your inverter. Your gonna need to cut this about 1-2 inches away from the inverter and strip both ends of the cables.
Now take the Y you just made using the crimps you crimped on connect the end with two wires in one crimp to the inverter wire and either (it dosent matter) of the other two wires to the wire that goes to your side light, Now you have one wire left over this should be connected to the wire that you run from your interior lights crimp it in,
Do this for the other passenger side too
Now you can connect up the wire to your footwell lights, I used a scotch lock to tap into the +ive feed of the light, i cable tied my wire so it didnt get caught up any where.
Test by locking and unlocking your car :)
Gone - '03 3.0i Z4 Roadster Sterling Grey -
Z4 Project Thread
Now got E64 '57 650i - My 650i
Bad_Pritt
Re: Trigger Angel Eyes to Come on/off When Unlock/Lock
Post by Bad_Pritt » Thu Aug 09, 2012 5:34 pm
Good write-up! But does this mean that the angels eyes only go on when unlocking, locking and when engine on and no headlights
So from the moment you turn your headlights on at night, the sidelights and thus agnel eyes are turned off?
I don't think I have those "side lights" but I noted that the "US indicator" option on my module makes the US indicators go off when I turn on the lights...
sam1832
Post by sam1832 » Thu Aug 09, 2012 5:41 pm
No they come on when you and unlock
When your interior lights go off they will go off
When you lock they will go off
To get them to come on as drl you will need to wire them to a switched live from somewhere instead of the side light wiring
Sent from my GT-I9300 using Tapatalk 2
Z4 Project Thread
Bad_Pritt
Post by Bad_Pritt » Thu Aug 09, 2012 5:48 pm
Thought so... With my comfort light module I have them on when locking and unlocking and when the lights are on, but I cannot get them on as drl. But I can have the outer indicator bulbs as feed for the angels, which I can put on when locking, unlocking and as drl. Those are then off when the lights go, but then I have a feed from the "side lights" that I can use. So if I understand your write-up correctly, I could have my AE's on all the time with both feeds, provided that I put a diode on each feed?
Steve220
Post by Steve220 » Thu Aug 09, 2012 5:53 pm
Please don't use scotch locks on car electrics, they're terrible, terrible things.
2006 Z4MC - Midnight Blue on CSL's!! :D ///M Power - Fun begins after 4k rpm ;)
Bad_Pritt
Post by Bad_Pritt » Thu Aug 09, 2012 6:05 pm
Steve220 wrote:Please don't use scotch locks on car electrics, they're terrible, terrible things.
But instead use...?
sam1832
Post by sam1832 » Thu Aug 09, 2012 6:20 pm
I've used one to tap into the footwell light +ive
Itsbhardly going to cause any problems
Could solder it but that's going to be more hassle than it's worth
Z4 Project Thread
BPM-Z4R
Post by BPM-Z4R » Thu Nov 15, 2012 12:43 am
What rating diode do you need? Cheers
iPhone 5 TapaTalking
Marius
Post by Marius » Wed Jan 02, 2013 8:32 pm
did you tired connect to the light switch , it would much simpler ?
BPM-Z4R
Post by BPM-Z4R » Thu Jan 03, 2013 12:44 am
What do you mean? They run as sidelights. I just want them to trigger when I unlock also
Bad_Pritt
Post by Bad_Pritt » Thu Jan 03, 2013 9:34 am
BPM-Z4R, you can also try this: http://www.z4-forum.com/forum/viewtopic.php?f=2&t=40688
a lot easier and more possibilities... My angels light up when locking/unlocking the car and they are also connected to the sidelights :wink:
sam1832
Post by sam1832 » Thu Jan 03, 2013 10:14 am
BPM-Z4R wrote:What rating diode do you need? Cheers
Sorry missed your post,
I will find you a link
Z4 Project Thread
sam1832
Post by sam1832 » Thu Jan 03, 2013 10:26 am
Get a
1n4001 diode
They are relatively common and very cheap (under 10p)
Z4 Project Thread
BPM-Z4R
Post by BPM-Z4R » Thu Jan 03, 2013 10:41 am
Cheers :thumbsup:
