Replaced my window regulator today!
Danderton
Bedfordshire
Afternoon All
Had a day off work today in lieu of some recent weekend work, so thought I would attempt to replace my drivers side window regulator.
It's been troublesome for the last 9 months or so, it would go up and down ok but starting making horrible noises the further down I put it. And on a couple of occasions when I forgot and put it all the way down it wouldn't come back up until I restarted the ignition. This was quite a pain as every time I wanted to lower the roof I would have to remember to manually put my drivers window down half way first, as the roof button sends it too far down.
Anyway, I purchased a whole new OEM regulator from Euro Car Parts for about £130 (with 25% discount code). It arrived a few weeks back. I read up a few guides on here which were very handy to get me started.
Begun at about 10.30 this morning, and finished around 14:30 this afternoon. However I was taking my time, drinking lots of tea, having kit kat breaks and I did have to pop up to Halfords in that time too.
I'm no mechanic. I work in IT. It's not a technically difficult job it's just a bit fiddly and definitely something to take your time with.
Few pics below which may give others confidence to do it.
Door Card Off
14066109556_5b3fd0d097_c.jpgZ4 Window Regulator by danrobinson7, on Flickr
Membrane Off
14066111286_184583602a_c.jpgZ4 Window Regulator by danrobinson7, on Flickr
14089678164_43ce5a4277_c.jpgZ4 Window Regulator by danrobinson7, on Flickr
Old Regulator out
13902617337_1254bcff68_c.jpgZ4 Window Regulator by danrobinson7, on Flickr
New Regulator ready
14086092322_58f1c1ec01_c.jpgZ4 Window Regulator by danrobinson7, on Flickr
Close Inspection of the OLD regulator you can see what was making the noise (freyed cable ready to snap)
14109301173_2165f2574a_c.jpgZ4 Window Regulator by danrobinson7, on Flickr
Compare the above to the cable on the new regulator below
13902609719_6d886d2279_c.jpgZ4 Window Regulator by danrobinson7, on Flickr
This Spring looked worn on the old regulator too
14066119126_2b83a1650d_c.jpgZ4 Window Regulator by danrobinson7, on Flickr
Put it all back together, tested and all appears to be working fine. I didn't even have to do a window reset, the auto up and down works fine.
No airbag lights on either as I was very patient each time I disconnected the battery (3-4 times during the whole task)
Lost half a day of my life that i'll never get back. But I gained some self satisfaction and a fully working window ready for summer!
Dan
Worth noting that a BMW indy quoted me £400-£500 for the above work. So by doing myself I saved between £270-370! :D
Cheers, I did see recently another member was charged about £800 for this which is crazy money.
Not sure if the old regulator is of any use to anyone else for parts!? Thought I'd mention it before I throw it in the bin. Probably not, but If so let me know, I'll be at the Duxford meet this sunday.
Dan
All done. 3hrs to complete which included sound proofing the door and door card while it was all accessible. Haven't been out in it yet to test the window fit for wind noise, hoping it's fine as it looks like a good tight fit.
