Bulb warning light - Latest update
- Marlon
Re: Bulb warning light - Help!
Right - Marvellous, I will live with it for a while until I decide what to do - may have to get my Indy to look at it.
Gone: 3.0si 2008 E85
911 997 Carrera S
You can try fiddling about in there but you really need to get the headlamp off to see what's going on. Not the hardest of jobs - clips on the side can be a pain. If you have washers you can just drop the bumper to the floor without needing to detach completely. You don't even need to lift the car.
- Number5
The bumper isn't hard to remove if you've got the space to do it. It will also give you chance to pop a couple of small 3mm holes in your Fog lamps, if they are misting up, and have a good clean around whist you're in there ?
Its much easier to test all the lamps when they're just hanging on a wire...
Alpina Roadster #307
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
10x E85 Se/Si Roadsters
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
- Marlon
Yeah, I hear what your saying fellas, but I'm lacking the space and the ability
911 997 Carrera S
- Marlon
At the risk of boring everyone to death, here's an update:
So we went out yesterday for the afternoon to the Lakes and had no warning light on the dash - I pulled over and checked the indicator and the bulb was working! It kept on working all the way to Keswick over an hour and a half drive. Then after lunch on the way to Windermere I indicated right and the warning light appeared and the indicator flashed rapidly
Then 5 minutes later it was working again - then it wasn't, then it was. So basically its an intermittent problem - don't you just love those
It didn't spoil the drive though - loved it, and weather was perfect (will post some pics in the gallery later this evening)
911 997 Carrera S
- enzed4
Yeah, ask me how I know... Now looking for replacement passenger side clip that holds bumper to wheel arch. I have the part number but will try repairing the damaged one (2 part epoxy glue wasn't strong enough).Scooba_Steve wrote: Not the hardest of jobs - clips on the side can be a pain.
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
- Marlon
Re: Bulb warning light - Latest update
Latest update: So the intermittent 'right indicator' problem seems to have gone away. Every time I indicate right I'm waiting for it to error - but since the last error about 10 days ago its been fine. Hope I haven't jinxed it now
911 997 Carrera S
- nb67
Never say never!!!Marlon wrote:Latest update: So the intermittent 'right indicator' problem seems to have gone away. Every time I indicate right I'm waiting for it to error - but since the last error about 10 days ago its been fine. Hope I haven't jinxed it now
In all seriousness Marlon, let's hope it's sorted itself out once and for all!!
GONE - 3.0i SE. Sterling Grey. 2005.
Gaptech RCH+, ZHP, Stubby. CDV Delete.
- Marlon
Thanks budnb67 wrote:Never say never!!!Marlon wrote:Latest update: So the intermittent 'right indicator' problem seems to have gone away. Every time I indicate right I'm waiting for it to error - but since the last error about 10 days ago its been fine. Hope I haven't jinxed it now
911 997 Carrera S
- Marlon
It's been over 4 weeks now since the indicator error - dare I say, it appears to have gone away
911 997 Carrera S
- mac27040
Not sure but you could try Navcoder and switch off bulb check for indicators, then you won't get the bulb warning light on dash.
3.0i SMG Supercharged,19" CSL, AvinUSA android 10.25” screen,DSP,M6 gearknob,Coilovers,Aero F-bumper,M r-bumper,Aero skirts,Facelift front & rear lights,M sports seats,Carbon Steering wheel,Intravee,Rervese cam,Hydrographics
- Marlon
Thanks, but it wasn't just a warning light - I was also getting rapid flashing indicator next to the problem bulb.mac27040 wrote:Not sure but you could try Navcoder and switch off bulb check for indicators, then you won't get the bulb warning light on dash.
911 997 Carrera S
- mac27040
Think you have covered it, rapid flashing indicates a bulb out. It's either bulb holder or cable issue.
- jack07
When dealing with these hard to pin down auto electrical issues,I have found little dose of switch cleaner into the joints/connectors goes a long way and tends to cure many ills.It is corrosive,so don't overdo it.I tend to leave the wire wool for plumbing as it sheds steel strands into places where you don't want shorting and new corrosion to start.Good luck with the job Let us know how it goes Sir!
This is the car I've been waiting for http://s611.photobucket.com/user/markhorner100/albums
- Marlon
So its now been 3 months since the indicator has thrown up an error, and I've been using the car most weekends and the odd evening
How long does it take for an 'intermittent' problem to be over I wonder
911 997 Carrera S
