I don't agree with pressure washing under the bonnet, it's to aggressive & will work its way into places you don't want water, a hosepipe is much less likely to cause problems under the bonnet imho
Engine Bay cleaner
- Smartbear
Engine Bay cleaner
e85 3.0si sold
- Gustavo7
Engine Bay cleaner
I used Gunk engine degreaser (spray version), let it work for a good 5-10min, rinsed it with a pressure washer from a distance (so low pressure was applied), turned the engine on to dry it all out. Sprayed Aerospace 303 protectant and wiped it all immediately.
Before: After: regards,
Gustavo
Gustavo
Imola Red Z4MC
- Smartbear
Engine Bay cleaner
Much better Gustavo you could eat your dinner off it now
e85 3.0si sold
- pvr
Engine Bay cleaner
If sellers did that before they sold the car, they would make it much more attractive.
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- Chris_D
Engine Bay cleaner
i think this has come up before as i seem to remember expressing a preference for an 'honest' dirty engine bay when i bought my zed due to seeing what had been tw@tted about with and what hadn't.pvr wrote:If sellers did that before they sold the car, they would make it much more attractive.
The patina on mine looked original and probably evolved from when the car was rolled off the production line. It was pretty in-ground and mucky apart from the engine oil filler cap and oil filter cap - confirming it's recent oil change. I just hope it wasn't it's ONLY oil change
Everything else looked 'un-touched' and tbh, that was a relief.
Spic and span now however!
- pvr
Engine Bay cleaner
Or you can say that they did not care for the car
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- NickDE
Engine Bay cleaner
+1patriot66 wrote: Start with a cold engine. Spray 10:1 diluted TFR (Traffic Film Remover) under the bonnet and all round the engine bay. Agitate any particularly grimy areas with a stiff brush. Pressure wash everything thoroughly.
I also use rubber gloves over any sensitive electrical bits to keep the water out
Darkness gone, go Darknes2, go Frozen, go Tronic
Engine Bay cleaner
Looks good, Gustavo - if it helps, you can actually leave 303 to dry and solely need to mop up drips/runs if you over use it. This way of working will provide a more uniform finish.Gustavo7 wrote:I used Gunk engine degreaser (spray version), let it work for a good 5-10min, rinsed it with a pressure washer from a distance (so low pressure was applied), turned the engine on to dry it all out. Sprayed Aerospace 303 protectant and wiped it all immediately.
regards,
Gustavo
