Headlight washer jet
- Roundozo
So I've only just noticed that the inevitable must have happened on the way back from work. I now seem to be missing my offside headlight washer and the cap associated with it.
Does anyone know where I can find a replacement washer jet (had a look on eBay and can only seem to find the lower section) and then also the cover cap. Need it in black.
I know RickRob was trying to paint his own but that sounded like it was producing less than desirable results.
Any help and advice greatly appreciated.
Past - Z4 Coupe, gone but not forgotten
Present - 530d M sport touring
- Zed Five
A common issue. Buy it from your dealer for about £10.
It is the easiest item in the world to spray paint. Stick it to some cardboard with bluetac beneath. Warm up, dust with paint. Let Dry. Dust with lacquer. Simples.
Why is it that people who can't take advice always insist on giving it?
E89 35is | BMW S1000rr Motorsport Ed.
I think there about £20 from a dealer, also on ebay for that. They will need spraying up too. There is one other problem, there is a small bracket that fits on top of the washer and that quite often goes missing too. I managed to get one via a forum member who has had them 3d printed via shapeways. Has anyone managed to get BMW to pay for a replacement under warranty as this seems to be a common fault
- RickRob
This is where I got my washer cover from:
http://www.ebay.co.uk/itm/BMW-NEW-GENUI ... SwJblXAmmm
The issues I had with painting were all of my own making! Once I read the instructions and took the advice from here - making sure paint and part were at room temperature - all went well:
Sorry I can't help re the washer as I only lost the cover on mine.
Good luck!
Good luck!
///M Roadster. 2007 Black/Black. Rear spoiler, whippy aerial, mud flaps and gimp-style wind deflector!
- bluespit
having just repaired mine (it was leaking) I'm not sure how you can lose one? it was a faff to get off, bumper off, clip into place and pipe clip hold the lot in place. Or am I'm misunderstanding?
now I'm about to have more time I've suddenly got less toys to play with!
- Roundozo
Thanks for the replies gents. Looks like I'll give painting it a go. If all else fails I'll pop to my local paint guy as he's fixed paint on my car before so I know he's got the colour.
Looking in the hole that is now taking pride of place on my front bumper I've definitely lost the majority of the unit. The lower pump section is still there however the whole upper unit (the bit that pops up and focuses the water on the light) is completely missing.
The most annoying thing is that the other side has been leaking for a while but never got round to fixing it however it now looks like Ive been forced into fixing the good one so I may as well now fix both.
- Roundozo
This is impossible. Does anyone know of anywhere I can buy a complete washer unit? I've now been searching since I noticed it's missing and I can't find anything. All that seems to turn up is the pump motor and not the nozzle.
- RickRob
Is this what you're after:Roundozo wrote:This is impossible. Does anyone know of anywhere I can buy a complete washer unit? I've now been searching since I noticed it's missing and I can't find anything. All that seems to turn up is the pump motor and not the nozzle.
http://www.ebay.co.uk/itm/231069835032? ... noapp=true
- Ewazix
I had to do mine with exactly the same bits missing, the washer unit is not a pump but a telescopic body with pop-up spray head like this. The cover fits on top of the diamond shaped clip on the top. Unfortunately the clip often departs with the cover, but the clip is only available with the whole spray unit, from BMW at about £80 last time I checked.
I ended up buying a complete front bumper on ebay, complete with sprays, covers, fog lamps and grills etc for the same money and sold on the bits I didn't need.
....... and check you get the correct unit, both the units and the covers are handed L/R
2018 Cooper S Countryman
Fiesta Ecoboost
Fiesta Ecoboost
- Roundozo
Thanks for the link RickRob but unfortunately that's the pump from the tank rather than the washer unit.RickRob wrote:Is this what you're after:Roundozo wrote:This is impossible. Does anyone know of anywhere I can buy a complete washer unit? I've now been searching since I noticed it's missing and I can't find anything. All that seems to turn up is the pump motor and not the nozzle.
- Roundozo
I don't suppose you have the part numbers do you? I can't find them anywhere.Ewazix wrote:I had to do mine with exactly the same bits missing, the washer unit is not a pump but a telescopic body with pop-up spray head like this. The cover fits on top of the diamond shaped clip on the top. Unfortunately the clip often departs with the cover, but the clip is only available with the whole spray unit, from BMW at about £80 last time I checked.
- Ewazix
Real OEM is your friendRoundozo wrote:I don't suppose you have the part numbers do you? I can't find them anywhere.Ewazix wrote:I had to do mine with exactly the same bits missing, the washer unit is not a pump but a telescopic body with pop-up spray head like this. The cover fits on top of the diamond shaped clip on the top. Unfortunately the clip often departs with the cover, but the clip is only available with the whole spray unit, from BMW at about £80 last time I checked.
There you go.. https://www.realoem.com/bmw/enUS/showpa ... Id=61_1604
Fiesta Ecoboost
Fiesta Ecoboost
- bluespit
Blimey I take it back. You've blown the bloody top off!
- Roundozo
Thanks! I did look on RealOEM but couldn't find it. Now to see if I can get them anywhere!Ewazix wrote:Real OEM is your friendRoundozo wrote:I don't suppose you have the part numbers do you? I can't find them anywhere.Ewazix wrote:I had to do mine with exactly the same bits missing, the washer unit is not a pump but a telescopic body with pop-up spray head like this. The cover fits on top of the diamond shaped clip on the top. Unfortunately the clip often departs with the cover, but the clip is only available with the whole spray unit, from BMW at about £80 last time I checked.
- Roundozo
Yup, I'm surprised I did see it fly off! I would have tried looking for it but I think it came off while on the M3 in lane 3 so even if it is there, there's no way of getting it back safely.bluespit wrote:
