Top-level navigation and sound system for z4 e85.(DIY)
- se4y
Re: Top-level navigation and sound system for z4 e85.(DIY)
1.The backboard of the OEM radio have a main plug socket A and it connected with plug B (with many wire). Your job is just seperate B from A and put new one E to A and put B to E.(it is particular for bmw and it would be good match )
2.Front camera paste in front windscreen.so you will find way for the wire.(same as mic or gps receiver,tv antenna )
3.Rear camera use the reversing light signal. You also need to find the way under the carpet in trunk.
4.Copy the nav soft ware to the SD card.(I use three kind of nav software in china .all of them are much more better than oem nav.I drive idrive bmv5 also.I don't use oem usually. The oem nav informations are limited in china and the nav system is not easy to operate.I also download a software make me know the camera in the road in advance by voice)
5.I think it much easy for garage if they know how to take out vent and the radio.
6.All difficults is to remake and dig the hole by handwork.
- se4y
yes! 5-6mm thick plastic. I use a Circular saws almost damage the air flue under it. it needs be careful. But more space under there fortunately.danmiddle2 wrote:It really shouldn't be all that difficult.Putter Whore wrote:Does look good. But I've filed under 'don't have the necessary skills / balls to do'. If only someone offered the fitted package for £500!
The hardest part is likely to be cutting the hole in the dash. The dash is so thick, with a layer of foam underpinned by some thick plastic, that it is quite time consuming... but certainly not difficult.
Sounds like a nice easy plug and play upgrade for anyone with the Nav already as it should fit in the same hole...? How does it play movies and TV though? What/Where are the inputs or does it use the existing BMW TV tuner for the TV and additional USB input for movies?
3.0i
- danmiddle2
+1 on the motorisation, doesn't look like it is to me... can't see a motor. I wouldn't have thought the screen would transfer over - looks to be the wrong size / aspect... although it is hard to tell.srhutch wrote:Presume the top isn't motorised. I would try and source a Z4 monitor housing and transfer the screen over.
I wouldn't have thought so... the template looks different to the original oneStug wrote:I wonder if it would fit straight into the hole that the o/e nav occupies?
I guess it might have enough of a surround to cover any differences between the two.
If you ever have to do another one, a dremel muti tool makes slightly lighter work of it.se4y wrote:yes! 5-6mm thick plastic. I use a Circular saws almost damage the air flue under it. it needs be careful. But more space under there fortunately.
- se4y
danmiddle2 wrote:+1 on the motorisation, doesn't look like it is to me... can't see a motor. I wouldn't have thought the screen would transfer over - looks to be the wrong size / aspect... although it is hard to tell.srhutch wrote:Presume the top isn't motorised. I would try and source a Z4 monitor housing and transfer the screen over.
- danmiddle2
They are awesome, aren't they?!se4y wrote:
- se4y
I used bosch with 10cm circluar saw. It is too cumbersome for the dash board.danmiddle2 wrote:They are awesome, aren't they?!se4y wrote:
- Alun1976
Why does the X3 sat nav screen let it down in your opinion? This upgrade (made for the X3) fits very nicely on the dash of the Z in this pics? What puts you off? I'm only asking as I can get an X3 screen to go with danmiddle option 2. I can't seem to get hold of a z4 one cheap.srhutch wrote:I'd prefer to go with Danmiddle2's option using an OEM housing with a tablet. The one for the X3 lets this down IMO.
Z4 3.0i Roadster (ESS TS2 supercharged, E36 M3 headers, AA methanol injection, E46 M3 Rear axle inc LSD, Brembo (Porsche) Brake upgrade, M3 CSL discs, KW V3 coilovers, Eibach wheel spacers, Miltek backbox, CDV delete, 6-speed illuminated M gear knob.)
- Alun1976
Does this fit nice and flush on the dash with no gaps? I was interested in buying an X3 screen to fit to my Z and go with danmiddle option 2 but want to make sure first that it fits perfectly?
Al
Al
- Alun1976
It looks like it fits nice and flush in the pics but just want to confirm this?
Aln
Aln
- se4y
Mine is perfect. It works nearly 3 years. No any problems. No any noise or unsteadiness when driving. I also upgrade the screen on Septemer 2013 for bluetooth music ,the new generation high quality screen and the driving recorder and the original sound music play(ten big than mp3).Alun1976 wrote:It looks like it fits nice and flush in the pics but just want to confirm this?
Aln
you can find your own way to install it. The original part is a little thick and a little crooked.I do the "knife works" myself first and find professinal technicist to help me with the other part.
you can try if you are good at diy and enjoy it.(Need time and patience).
- Alun1976
So are you saying that the OEM X3 screen is thick and crooked and that the aftermarket screen fits better? If that's the case then I will have to go with the Z4 screen for the android system option. The reason I ask is that plenty of X3 faulty screens come available and not many Z4 screens and the price can be double for the Z4 screen.
Alun
Alun
- se4y
old X3:(the radio and nav screen is similar to z4 but little different )Alun1976 wrote:So are you saying that the OEM X3 screen is thick and crooked and that the aftermarket screen fits better? If that's the case then I will have to go with the Z4 screen for the android system option. The reason I ask is that plenty of X3 faulty screens come available and not many Z4 screens and the price can be double for the Z4 screen.
Alun
new X3:
The Electronic products update fast and have more function of the attractive.And I can't find oem screen with so many functions. Z4 is less as you know.The aftermarket factory would not make mould for z4.
- LukeMace
Thinking more about this!
3.0, Quad Conversion, 19" CSLs, Bucket Seats, Big Brake Conversion, Lowered 40mm, AE and Clear Hockeys etc...
CLICK HERE FOR THE BUILD THREAD
- si-forks
I still want it in my Z you go first luke
sent by galaxy S4 on tapatalk
