Question for anyone with a quaife atb?
- Ducklakeview
Have noticed recently if I go from reversing to drive, a faint noise as I initially pull away. I THINK it's just the rollers moving from one end of their pockets to the other fire to the change in direction. Anyone else get this?
Mike
Mike
- markeg
ping Perry Gunn, he has one fitted. Mind you, he'd have to drive it to help you out....
previous: Alpina Roadster S, #108: gone
current: MB C-class
"veni, vidi, velcro - I came, I saw, I stuck around..."
current: MB C-class
- Ducklakeview
- markplant
I know it's a different diff but machine monkey has a m factory diff, you could speak with mat an see if he has similar thoughts
- Machine monkey
I do Mark but it’s of a different design and work differently. I get no noise but your probably right Mike it’s just the lockers moving up there locking ramp angles!
Mat
- Ducklakeview
- Ducklakeview
X posted..Machine monkey wrote: ↑Mon Dec 04, 2017 9:34 pmI do Mark but it’s of a different design and work differently. I get no noise but your probably right Mike it’s just the lockers moving up there locking ramp angles!
Mat
That's what I'm thinking, it had less than 200 miles on it when it went in, and now has about 3k on it. Not worried about it, as that's the only time it does it, just wondered if it was "normal" for them..
Mike
- TomK
He was referring to an M factory diff not a BMW M (factory!) diff, though I can see why you'd read it like that They're helical I think so pretty similar to the torsen quaife I'd have thought? Doesn't the quaife deal with the issue with those type of diffs where one wheel will loose all drive if completely unloaded, or something like that?Ducklakeview wrote: ↑Mon Dec 04, 2017 9:34 pm///M is a clutch type LSD, completely different internals.
Mike
- Ducklakeview
Yes, I believe the quaife overcomes that issue, came say I've yet put that particular bit to the test, yet..TomK wrote: ↑Mon Dec 04, 2017 11:51 pmHe was referring to an M factory diff not a BMW M (factory!) diff, though I can see why you'd read it like that They're helical I think so pretty similar to the torsen quaife I'd have thought? Doesn't the quaife deal with the issue with those type of diffs where one wheel will loose all drive if completely unloaded, or something like that?Ducklakeview wrote: ↑Mon Dec 04, 2017 9:34 pm///M is a clutch type LSD, completely different internals.
Mike
Mike
- TomK
Lol, no I can't imagine it's an easy to create scenario, excepting the obvious one of an icy puddle on one side of the road...Ducklakeview wrote: ↑Tue Dec 05, 2017 12:06 amYes, I believe the quaife overcomes that issue, came say I've yet put that particular bit to the test, yet..TomK wrote: ↑Mon Dec 04, 2017 11:51 pmHe was referring to an M factory diff not a BMW M (factory!) diff, though I can see why you'd read it like that They're helical I think so pretty similar to the torsen quaife I'd have thought? Doesn't the quaife deal with the issue with those type of diffs where one wheel will loose all drive if completely unloaded, or something like that?Ducklakeview wrote: ↑Mon Dec 04, 2017 9:34 pm
Mike
Mike
- Ducklakeview
Yup or British summer as it's called...TomK wrote: ↑Tue Dec 05, 2017 12:39 amLol, no I can't imagine it's an easy to create scenario, excepting the obvious one of an icy puddle on one side of the road...Ducklakeview wrote: ↑Tue Dec 05, 2017 12:06 amYes, I believe the quaife overcomes that issue, came say I've yet put that particular bit to the test, yet..TomK wrote: ↑Mon Dec 04, 2017 11:51 pm
Mike
Mike
- Steve84N
I haven't noticed any more clunking than before. There is a small noise going from reverse to forwards.
C63 AMG Estate 6208cc
- GuidoK
My Quaife diff makes no noise.
I have it in for 7 years now.
- Ducklakeview
I have one and there has never been any noise in any circumstance. Nobody would know it was an LSD from listening alone.
