Threading Wires through the Boot/Seat rear Bulkhead....
DannyBoy
X-Box live gamer tag: Nailinator (PS3 Tag)
Post by DannyBoy » Tue Apr 28, 2009 10:58 am
As per the title.
I have a DICE module installed that currently resides in the boot. Now I have no issue with this but would rather have the "input end (where you plug the ipod) to sit in the box between the seats.
My question is how do you thread wire through the bulkhead? I had a look this weekend and cannot see any holes nor any area where I could potentially feed it and its a bit of a concern as its something I'd really like to do. Anyone able direct me? :wink:
Danke in advance.
2004-2005: "04" Saph 2.2i; 2007-2010: "05" Tit 3.0i; 2010-2012: "08" Audi TTR;
2012+ "MY13" Audi TTC TFSi S-line Black with 19s and lots of toys
srhutch
Re: Threading Wires through the Boot/Seat rear Bulkhead....
Post by srhutch » Tue Apr 28, 2009 1:15 pm
Unless I am not reading your post correct there is a bloody get hole in the bulkhead between the seats if you pull the boot liner out.
pvr
Post by pvr » Tue Apr 28, 2009 1:38 pm
911-50 Black - unique spec
X5 40d - full fat comfort
Abarth 595 Comp.
Jeep
DannyBoy
Post by DannyBoy » Tue Apr 28, 2009 2:26 pm
Cool beans people, so to summise there is hole in the middle which can be clearly seen when the fabric is removed, great.
I assume the cubby hole boxes in the bulkhead are relatively easy to remove from the front and this is a two min job. Thanks for the pic PVR.
Good stuff. :thumbsup:
rob davey
Post by rob davey » Tue Apr 28, 2009 3:32 pm
DannyBoy wrote:so to summise there is hole in the middle which can be clearly seen when the fabric is removed
that was a more polite way to put it :lol:
BMW Z4 2.0i SE Roadster (2006 / 06) Facelift, titanium silver, black 108s, stubbie, sports wheel & gear knob, leather seats & bum warmers, drivers side FAB, cup holders and aux input
gannet
Post by gannet » Tue Apr 28, 2009 3:35 pm
DannyBoy wrote:I assume the cubby hole boxes in the bulkhead are relatively easy to remove from the front and this is a two min job. Thanks for the pic PVR.
not so sure that part is so straight forward, other threads reference having to take apart most of the console...
-- Gannet.
Current: MINI JCW... - Modification: Driver Upgraded :D
Previous: DS3 DSport, Z4 3.0SE, 206 GTi & XS, Alfa 147 Lusso
DannyBoy
Post by DannyBoy » Tue Apr 28, 2009 4:12 pm
gannet wrote:[quote="DannyBoy"I assume the cubby hole boxes in the bulkhead are relatively easy to remove from the front and this is a two min job. Thanks for the pic PVR.
In that case I'll make sure I dont attempt it having had a drink. :rofl:
srhutch
Post by srhutch » Tue Apr 28, 2009 10:44 pm
DannyBoy
If all you want to do is feed a wire through members have done this without removing the interior centre console. I'm not saying it's easy but there have made just enough space between a CD changer and the cubby hole, or you could drill a hole in the back of the cubby hole from the boot and feed through from there.
PVR has done lots of work in this area so would accept what he says :thumbsup:
DannyBoy
Post by DannyBoy » Tue Apr 28, 2009 10:50 pm
Coolio Hutch I think your latter suggestion will be the one to follow.
I'll have a crack at it this weekend and then my newly acquired IPOD touch will have no reason to make me get out the flippin car and reattach it in the boot every time I turn the ignition off!
srhutch
Post by srhutch » Tue Apr 28, 2009 10:57 pm
DannyBoy
good luck, If I could drill a hole, probably the option I would choose, but worst case you may need to remove the centre rear panel, it's not hard to do but a little time consuming. I did this to install satNav.
Online
cj10jeeper
Moderator
Moderator
Post by cj10jeeper » Tue Apr 28, 2009 10:57 pm
Not forgetting that in the top left hand corner of the boot there is a huge access hole which comes out behind the passenger seat behind the small grille.
This is the point that BMW use to run some of the front to rear looms through. I had to use it to retrofit the bluetooth cabling through to the centre console.
BTW - nothing is easy on running cables around the Z4. I've done them all over the place and all are tight and fiddly :thumbsdown:
srhutch
Post by srhutch » Tue Apr 28, 2009 11:12 pm
cj10jeeper wrote:Not forgetting that in the top left hand corner of the boot there is a huge access hole which comes out behind the passenger seat behind the small grille.
SatNav cable also routed through this hole and plugs into same connectors.
DannyBoy
Post by DannyBoy » Tue Apr 28, 2009 11:14 pm
Thanks Phil but reckon that might be beyond my technical scope! Will stick with the drill idea as its more me. :thumbsup:
srhutch
Post by srhutch » Tue Apr 28, 2009 11:24 pm
DannyBoy wrote:Thanks Phil but reckon that might be beyond my technical scope! Will stick with the drill idea as its more me. :thumbsup:
I'm assuming the dice plugs into where the CD changer is connected so the centre cubby is your best bet.
Online
cj10jeeper
Moderator
Moderator
Post by cj10jeeper » Wed Apr 29, 2009 8:54 am
There is no way I would drill a hole through the rear bulkhead given the work involved Vs threading through an existing hole. You'll need to drill a much larger hole, rustproof/paint it and then insert a rubber grommet to prevent chaffing.
Who is online
Users browsing this forum: 36valley, Boris, Chris_D, English68, MrPT, rscob and 9 guests
