2.5i Sound Generator
- Popey
Ive had a nosey round but couldnt find any info on the sound generator for the 2.5i (its auto too).
I have found this on rOEM, does anyonw have a full parts listing with costs?
http://www.realoem.com/bmw/showparts.do ... g=13&fg=20
Re: 2.5i Sound Generator
13-74-7-514-863 SOUND GENERATOR 1 £61.00
13-71-9-071-752 KIT 1 £1.26
13-74-7-518-282 BRACKET 1 £1.55
11-61-1-705-032 (11-61-5-533-331) OVAL HEAD SCREW 1 £0.49
07-12-9-952-121 CLAMP 1 (not needed provided with item 1)
13-74-7-514-864 SOUND PIPE 1 £21.10
13-71-7-514-865 GROMMET 1 £2.95
13-54-7-514-867 RUBBER BOOT 1 £21.81
there ya go, I fitted this to mine about 3 weeks ago.
http://www.zpost.com/forums/showthread.php?t=63037
instructions too
instructions too
- Popey
Thanks very much
Also is the 2.5 airbox the same as the 3.0? I fancy an ITG filter but they only list 3.0. I noticed on the K&N website its the same panel for the 2.5 and 3.0???
- Popey
oh and how did you find the fit, did you put the foam in or leave it out (if this is an option on the 2.5?)
the 3.0 elbow is slightly larger than the 2.5 where the 80mm Hose clip fits, I cut a slice off the old elbow about 10mm wide and put that in to pack out the difference. I took one foam piece out, the one nearest the footwell.Popey wrote:oh and how did you find the fit, did you put the foam in or leave it out (if this is an option on the 2.5?)
- Popey
How does it sound?
- Popey
May I ask how much it costs in the UK?
if you add up all the numbers after the "£" signs, it will give you an idea......Popey wrote:May I ask how much it costs in the UK?
- Popey
gookah wrote:if you add up all the numbers after the "£" signs, it will give you an idea......Popey wrote:May I ask how much it costs in the UK?
- Popey
Real OEM show this for the 3.0
http://www.realoem.com/bmw/diagrams/v/p/170.png
And this for the 2.5
http://www.realoem.com/bmw/diagrams/i/v/230.png
However as yours works, it must be right
Aaaah but the above is really for the two different engine types, not just engine size. First one is for the M54 engine and the other is for the N52 engine,Popey wrote:Real OEM show this for the 3.0
Early engines were the M54 type, and later engines changed to the N52 type.. You will need to check which engine type you have,
I quoted parts for the M54 engine, because the 3.0 M54 engine had the sound generator as standard, but the 2.5 M54 did not.
The 2.5 N52 engine has the sound generator as standard I believe, so If your 2.5 engine does not have a sound generator it probably is the M54 type....
- Popey
No sound generator on mine and its an N52, just checked the paperwork (maybe it was on the Si only?)
So what parts do I need for mine, I cant work it out from Real OEM .
(think I owe you pint in your ever up this way)
- chris
This was on another thread, and trying to see what the point of this thing is. May sound really stupid, but i take it its just for engine sound obviously, but surely if you take out the filters then its sucking in air from the cabin?
Sorry just never seen anything like this on an engine
- Popey
Not sure how it works, but Im told it sounds rather nice
