Fitting? Gaptech - Worth the outlay - Now buying.
- Disca
Re: Gaptech - Worth the outlay?
The RCH+ was definitely the best mod I ever did, had it on both cars.
He who has the most toys, wins.
‘15 VFR1200FD
‘15 VFR1200FD
- enzed4
Just bought one.... the power of Forum persuasion - I hate you all
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
- Smartbear
The scotchclips supplied with them can be temperamental, after a couple of gremlins I removed mine & used electricians chocolate block instead, it's been 100% ever since
Regards
Regards
e85 3.0si sold
- JINGLE
i had read the supplied blocks could be a pain, and low and behold.... the 1st time it clipped them all together it didn't work
although..... a quick wiggle and recheck of them all and it worked fine and has done ever since (a year) I suppose its just down to luck/skill how well you connect the clips (more luck in my case haha)
I'm tempted but even with 25% off I still think they're expensive. I can already lower the roof using my key fob and find it hard to justify £95 just for the one touch feature and being able to raise the hood from the fob, especially as I've got an auto so holding my finger on the button as I pull away isn't difficult.
No doubt I'll end up buying one anyway
Z4R 3.0si Sport auto. So far: 19" CSLs, Eibachs, MM exhaust tips, de-badged rear, stubby, black grilles, spacers, aux cable, interior LEDs, LED boot strip......
Deffo good to know as I had not thought of a passenger pressing the roof button at 100mph instead of heated seats or something
2003 2.5 silvery goldish
gaptech,19" ispiris,iPod kit,xcite halos,load of petrol
- Disca
They tend to hold most of their re-sale value when taken off if the car is sold. So it's not like you are throwing the money away, someone normally buys it up pretty quick!STUBOY2UK wrote:I'm tempted but even with 25% off I still think they're expensive. I can already lower the roof using my key fob and find it hard to justify £95 just for the one touch feature and being able to raise the hood from the fob, especially as I've got an auto so holding my finger on the button as I pull away isn't difficult.
‘15 VFR1200FD
‘15 VFR1200FD
- PerryGunn
Smartbear wrote:The scotchclips supplied with them can be temperamental, after a couple of gremlins I removed mine & used electricians chocolate block instead, it's been 100% ever since
Personally, I don't like them as they partially sever the wire, this creates a weak spot that can break. I'd rather cut the wire and crimp on insulated bullet connectors instead. Crimping is the preferred way to make a strong physical connection between wires as it gives a more consistent connection and also reduces strain as the end of crimped connector grips the insulation of the wire rather than the wire itself.JINGLE wrote:i had read the supplied blocks could be a pain, and low and behold.... the 1st time it clipped them all together it didn't work
Alpina Roadster S #320
* Quaife ATB LSD * StrongStrut Braces * Turner RTAB Limiters * Gap-Tech RCH+ *
* Intravee & KCA-420i * Mini 0806 * Cheetah C550 * Stubby *
- PerryGunn
But you'll love us once it's fitted...enzed4 wrote:Just bought one.... the power of Forum persuasion - I hate you all
- markeg
Ah, so you're the one with the "flimper" spec'd AlpinaNumber5 wrote:I've not fitted one, purely due to the fact i cant justify £95 to save walking another few paces to the car.
You can open the roof on pre-2005 by holding the key in the door, so you still dont need to get in it, if its hot.
£50 I'd be tempted - £100 I 'm not (...yet !)
previous: Alpina Roadster S, #108: gone
current: MB C-class
"veni, vidi, velcro - I came, I saw, I stuck around..."
current: MB C-class
- PerryGunn
markeg wrote:Ah, so you're the one with the "flimper" spec'd AlpinaNumber5 wrote:I've not fitted one, purely due to the fact i cant justify £95 to save walking another few paces to the car.
- Number5
Yep. Because I have all my toys here...!!PerryGunn wrote:markeg wrote:Ah, so you're the one with the "flimper" spec'd AlpinaNumber5 wrote:I've not fitted one, purely due to the fact i cant justify £95 to save walking another few paces to the car.
www.z4-forum.com/forum/viewtopic.php?f=42&t=83912
Alpina Roadster #307
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
10x E85 Se/Si Roadsters
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
- DanStarr
Worth the buy in my mind and be easy to sell on if you ever part with the Z!
53 2.5 Maldives blue, gone but not forgotten.
53 Vauxhall VX220 2.2
- enzed4
Unless SkiPi's all-in-one module comes to fruition and works as well as it looks like it will. Then I suspect the market may be flooded with unloved Gaptech modules...
Gone: 2010 35i DCT
- nb67
What is this witchcraft you speak of? A Gaptech replacement?enzed4 wrote:Unless SkiPi's all-in-one module comes to fruition and works as well as it looks like it will. Then I suspect the market may be flooded with unloved Gaptech modules...
GONE - 3.0i SE. Sterling Grey. 2005.
Gaptech RCH+, ZHP, Stubby. CDV Delete.
