CCV delete. Anyone do it?
- Chris_D
So there's a school of thought which believes that getting rid of the ccv system in it's entirety has some credibility.
It's fairly well-documented with regards to how to actually bypass it- downtube from cam cover to a catch can etc, but has anyone here actually done it and reapd the benefits?
do you mean CDV delete?
No, I see catch can there. I've not read of anyone doing it.
- GuidoK
he means ccv if he's talking about a catch can.
I dont see any real benefit in deleting the ccv system other than that the ccv can fail/get clogged over time. Or is there some other benefit you're looking for?
There must always be some kind of ventilation present otherwise you'll get huge oil leaks.
I dont have the original ccv system anymore (I have a twinscrew supercharger), where the vent hose from the valvecover goes directly to the inlet of the supercharger (there is a valve inbetween so there is only suction when boost is off).
There's no real oil useage. I dont have a catch can inbetween there but I'm planning to put one there to monitor how much oil goes through that.
But as I said, I have no drain anymore to the dipstick tube.
surely deleting it will just cause a vacuum problem in system and mpg/oil consumption will fall badly im guesing
- Chris_D
yep, i meant crank case ventilation delete.
reason i ask is that i'm replacing mine with the cold-climate version which is bigger (due to valce insulation) and now requires me to take the whole inlet manifold off just so i can fit it properly. which means i have to wait for more bloody spare parts (inlet manifold gaskets).
tbh, i wish i'd have deleted it for the amount of time it's taking!
i saw many M54 owners, esp in the US have deleted and installed a catch-can with a hose running from vcg and 'distribution piece' holes blocked off.
However, i'm plodding on replacing it....slowly.....
- GuidoK
Why are you installing the cold climate one?
As far as I know there are 2 main reasons why they fail, one being that the internal rubber membrane disintegrates over time and the other one is clogging up, presumably due to a mix of oil and water vapour creating sludge (typical for cars that are started often in cold weather but run for very small distances, preventing the system to warm up properly).
Will the cold climate one prevent these problems?
Repearing the stock one is a fairly simple job I think?
- Smartbear
Hi, I think the cold climate version of ccv is insulated & heated to prevent the oil mist from condensing prematurely in the pipes & sludging up-it sounds as though it could help combat the harm that using the car for short journeys can cause with the oil not getting hot enough, for long enough.
e85 3.0si sold
- Chris_D
Yep, it's insulated which will help to regulate the temperatures that the crappy thin plastic tubing is susceptible to. It's essentially a bit of future-proofing as well as 'winterizing' my car as i'll be travelling to Poland (gdansk) as well as switzerland and norway over the winter months.
Having worked with polymers in the aviation industry, it's well acknowledged that temp fluctuations contribute to accellerated polymer degradation, so its just playing safer than i prob need to really while i have the opportunity.
However, tackling the replacement myself, not being a mechanic, is turning out to be more of an effort than i was expecting.
Hey ho.
Twin screw supercharger guido? Wow. U need to get some engine bay vids up on ur youtube channel...
Hey ho.
you may as well go for it then and try it if ohters have I wouldnt worry to much it must be ok
Not having looked at the pipes myself yet but would it not be possible to insulate the existing pipes?
- GuidoK
I think its more the valve and the swirl bowl that will be difficult to insulate.
Definately a good idea to swap the the cold weather one if you're going to poland or norway in wintertime.
But driving longer journeys is even more important as that dissolves the sludge; the insulated one can only prevent that sludge freezing up.
Some people also put a one way valve in the return line (to the dipstick outlet), but I think thats not a good idea. Most check valves have a spring and steel ball inside. The oil return is gravity fed and thats not strong enough to press the spring in a check valve so it will stay closed.
Easy to check though. (put a hose on top with a few drops of oil in it and see if it passes the checkvalve)
- Chris_D
Well, the intake manifold is off today so its all or nothing i suppose!
New ccv valve connected to the difficult s-bend hose section, impossible to do without taking manifold off with cold climate version.
What a PITA!
Still think bypass/delete could have been a viable option.
What a PITA!
Theres post i was reading today on e46 forum today. Some guy has done the same CCV delete with catch can. Is now getting fuel trim error codes.
That can only be coincidence, surely. The vent is directly into the manifold and there's nothing to measure that to know it's not being burnt.
