- Rusky
Added a set of locking wheel nuts to my newly refurbed wheels and installed led internal and reg lights.
3.0l Silver SMG, whippy and ginge fringe/ Sound gen mod/ Media bridge fitted (bluetooth and audio streaming) / Clear third break light/ Hard Top/ Eibachs springs and DLV back box/ Roof motor in the boot/ plus lots more.
Scoop fitted what a pita but this helped matters along
2004 z4 30i auto Toledo blue stubby Areo front back sideskirts and rear spoiler M/// MFSW DLV exhaust mod mma tips vanos overhaul 108s refurbed ram air scoop E46 M3 heated seats clear rear lights M/// sport black grills
also noticed I knocked paint of scoop so will have to touch up
- Danz4coupe
Fitted seatbelt pads so I don't feel like my head is being slowly cut off as I drive, washed it and took a pic of it.
Dlv exhaust mod highly recommend
- markeg
Cleaned up the fog lamps - very pitted after 12 years of road grit & salt, sanded down with drill pads, 240 grit through 400, 800, 1200 and 1500 grit, final polish with pads & chemical guys polish V34, v36 and v38. Sparkling now, going to look for some Lamin-x protectors before I refit
previous: Alpina Roadster S, #108: gone
current: MB C-class
"veni, vidi, velcro - I came, I saw, I stuck around..."
current: MB C-class
- patriot66
They look brand new markeg ! Excellent job.
Nothing, but bowser134 moved my roof motor into the boot, it was pretty much dead and full of water but now it works better than ever, highly recommend
E85 3.0
- buzyg
Finished off popping new drop links on, then a quick wash.
Need to replace brake bleed nipples too.
- WP_20170805_015.jpg (195.4 KiB) Viewed 1221 times
- WP_20170805_011.jpg (120.97 KiB) Viewed 1221 times
2005 e85 z4, 2.5
- Silverzedtom
Just given mine a proper go over inside. Leather cleaner, care balm, dash shine... the works.
Bloody hate doing the interior but love it when it looks clean.
E85 2.5si
F55 Cooper S
F55 Cooper S
- markeg
Started to rebuild my split headlights... new angel eyes (went for some ccfl this time) with 80mm diffusers, repainted inners, new "chaser" indicator and running light, cleaned lens, replaced one failed stepper motor... just finishing the wiring now, then I'll stick a thread up.
Oh, and ordered some lamin-x headlight and fog light protectors
current: MB C-class
current: MB C-class
- oldgitdave
Renovo'd the roof (3 stage over the last 3 days), not touched for at least 2 years. Looks great. Fitted LED' s to rear number plate, map reading lights & footwells. Main central courtesy LED wouldn't fit so have ordered another.
Tried to get the centre storage compartment between the seat backs open again & failed miserably Any advise greatly appreciated here guys! 2004 reg E85 but doesn't seem to have the release in the boot, unless it's behind the bulkhead carpet?
Bought an Aux lead & Bluetooth adaptor to be fitted later so I can stream Planet Rock Not that I want to drown out the lovely sound of that straight 6
Zedless
Jacked the coupe up and had the wheels off, and cleaned up the wheel bolts/nuts . Then re-coated in Hammerite Satin black.
New wheels ( Mv3 refurbed) and Goodyear Eagle F1 A3 being delivered tomorrow!
I also re-cleaned and oiled various bits in the wheel arches, like brake lines and various holders that had surface rust. Sprayed original Black on to the wheel arch liners.
It's a black plastic disc on the carpet, looks like a big button.oldgitdave wrote: ↑Sun Aug 06, 2017 7:30 pm Tried to get the centre storage compartment between the seat backs open again & failed miserably Any advise greatly appreciated here guys! 2004 reg E85 but doesn't seem to have the release in the boot, unless it's behind the bulkhead carpet?
E85 3.0
