Brake Calipers
Brake Calipers
Hi
Does anyone know the best calipers (other than BMW ones) to buy
for a 2005 Z4 2.0i
for a 2005 Z4 2.0i
OnlineEd Doe
Brake Calipers
What are you trying to achieve, performance or Aesthetics?
Various pricey options for increasing performance and improving Aesthetics - D2, AP racing, stop tech, hispec etc... Or there are adapter kits for the 6 pot bmw performance calipers, or porsche Boxster s calipers to go with M discs.
For improving performance on a more modest budget I'd suggest some decent pads on oe discs.
Before doing anything though I'd recommend a brake fluid change.
Carbon Black '07 M Coupe: Intrax 1k2 Coilovers, AP-Racing, Raybestos ST45s, Tillets, Schroth, Vibratechnic, Apex EC7, Strongstrut, Eventuri, H&S, RTD, 4.1FD
Silver Grey '06 3.0si Coupe - SOLD
- cj10jeeper
Brake Calipers
If you provide more detail to f what you want to achieve it will help make answers better focussed
For a straight replacement Europarts do some good deals
- kis
Brake Calipers
As a cheap option you can retrofit e46 330 brakes? A good guide available here which I used for my upgrade project. What was your intention with the calliper change? Performance?jaydon9269 wrote:Hi
for a 2005 Z4 2.0i
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
Brake Calipers
it's actually not that cheap if you use good parts ,and it's not worth the hassle because they not goanna be anything you expect them to be .kis wrote:As a cheap option you can retrofit e46 330 brakes? A good guide available here which I used for my upgrade project. What was your intention with the calliper change? Performance?jaydon9269 wrote:Hi
for a 2005 Z4 2.0i
- cj10jeeper
Brake Calipers
Marius - I have to disagree about the difference. It's considerable, having had the car before and driven on it for several years post conversion. It's with good reason BMW upgraded to these as standard post facelift on larger engine variantsMarius wrote:it's actually not that cheap if you use good parts ,and it's not worth the hassle because they not goanna be anything you expect them to be .kis wrote:As a cheap option you can retrofit e46 330 brakes? A good guide available here which I used for my upgrade project. What was your intention with the calliper change? Performance?jaydon9269 wrote:Hi
for a 2005 Z4 2.0i
Parts can be expensive if you buy the lot straight off, but nothing compared to so called big brake conversions. If you time it to when you need new disks and pads then a pair of calipers at £80 each, carriers from a breakers (if you cant find calipers) is all the incremental cost plus slightly more for pads and disks
- Joycey
Brake Calipers
Second that Cj, I do this mod for quite a few z3 owners who have the 1.9-2.2 engine sizes. The difference is very noticeable.cj10jeeper wrote:Marius - I have to disagree about the difference. It's considerable, having had the car before and driven on it for several years post conversion. It's with good reason BMW upgraded to these as standard post facelift on larger engine variantsMarius wrote:it's actually not that cheap if you use good parts ,and it's not worth the hassle because they not goanna be anything you expect them to be .kis wrote:
Brake Calipers
Hi, Thank you for the replay to my question.cj10jeeper wrote:If you provide more detail to f what you want to achieve it will help make answers better focussed
It was actually just for a straight replacement. My front right calliper
looks as if it is the original one fitted when the Z4 was new in 2005
It's showing a lot of rust and spoiling the look of the wheel.
The front left calliper looks a lot better and looks as if it has been
replaced since the car was registered.
It may be wiser to wait until I need front pads and replace everything
at the same time.
OnlineEd Doe
Brake Calipers
Wouldn't bother replacing them if there's just a little corrosion on the outside face. Wire brush it with some brake cleaner and spray it silver or something and it'll look much fresher for almost no outlay at all. I did this to mine a year ago, it still looks fine now!
- Ducklakeview
Brake Calipers
I "upgraded" mine with (new) bigger 325mm discs and used calipers from a 330d, the difference was vast, and I already had 300mm discs as mine is a 3.0L. Stopping power and pedal feel were greatly improved.
Mike
Mike
- kis
Brake Calipers
I'd echo what's been said already. You don't really need to change them. If the 'rusty' one is old and ceasing then that's a different story.jaydon9269 wrote:Hi, Thank you for the replay to my question.cj10jeeper wrote:If you provide more detail to f what you want to achieve it will help make answers better focussed
at the same time.
If you're after more performance based change then the e46 330 (petrol or diesel) front calipers are direct bolt on like Ducklakeview said.
Otherwise just stick with a wire brush and a coat of hammerite in your choice of colour!
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
