Number plate lights... ticked off the list
- MartynFrancis
So, I wanted to update the number plate lights for some time. I've had some Amazon vouchers hanging around so thought I'd take a punt on some that were supposedly for a 1 series for £17.
This is the kit, it appears the item is currently out of stock but this is what I bought....
Anyway, back to business..
This was before...
Bit dull, and boring. So I got them out and found the connectors were nothing like in the kit I bought.... uh oh!
So I put it all back together and gave up. Cracked open a Friday night beer and thought, whatthe hell let's just dismantle the whole original connector and push the pins directly onto the new light fitting......
Voila, they work! Unfortunately i forgot to take some outs of the connectors completely dismantled, but what I did do was wrap a small amount of insulation tape round the two pins to separate them do they didn't touch when pushed on the new fitting.
Really happy with the result and for £17 can't complain in the slightest!
This was before...
Silver 3.0si auto with flappy paddles and loving it! MM tips
Sterling grey 2.5i gap tech rch goodyear eagle F1, parrot MKi9100..... Stubby...... Written off
Those connectors with the W5W socket adapter are no good, I had one which shorted and melted. You could probably source a matching socket for the ones on the car and put them on the connector for your units.
That or the BMW LED ones from the 1 series fit with replacement BMW connectors.
- MartynFrancis
I probably will at some point, the metal crimps (if that's what they're called) at the end of the cables from the loom felt really nice and snug directly on the new light fittings. Bit of insulation tape was put to stop the two connectors touching, but everything felt really snug, and the fittings themselves it really nicely into the bumper.
I just bought official bmw 1 series ones they was 9 quid each + couple of quid for connectors, which when you unclip the z4s you can clip into new ones onto wires
Been on nearly 2 years now, still working
- kis
Is there nothing that's plug and play?
What sort of connectors do you need to switch the 1 Series to suit the Zed?
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
They are keyed to accept a one way connector for use with the LED units as they are obviously polarity sensitive. The Z4 connectors are not keyed in the same way as there was no need with bulbs.
All you do is remove the pins from the old connector, insert them into the new and you're good to go.
its basically the exact same connector, but as said the outer part is keyed (notched) so only fits in one way
all infos here
viewtopic.php?t=74890
the later 1 series has smaller leds and has them small square connectors
all infos here
- kis
Cheers biojo that link helped piece it together.
Scooba_Steve you got a part number? Had a quick look on Real OEM and not sure which variant of 1 Series to search under
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
The only issue I have with mine (and most others I've seen), is that they're so bright that you can't see the top of the number plate at night.
Mine (on old plate)...
think its these i got
63 26 7 193 294
http://bmwfans.info/parts-catalog/63267193294
BMW had them in stock, so just matched size up
These where wrong ones much shorter
63 26 7 193 294
For the full LED rear, complement these with brake, indicator and reverse lamps
