What device gives oil temp please ?!
- Ed Doe
Are you sure the n52 3.0si engine has an oil temp sensor? I was under the impression it didn't.... If anyone can confirm before I bother purchasing the torque pro app it would be appreciated! Cheers
Carbon Black '07 M Coupe: Intrax 1k2 Coilovers, AP-Racing, Raybestos ST45s, Tillets, Schroth, Vibratechnic, Apex EC7, Strongstrut, Eventuri, H&S, RTD, 4.1FD
Silver Grey '06 3.0si Coupe - SOLD
- Zed4our
Looks a good deal but would be too big to use in car I think.
Ed doe, the garage I used plugged an expensive Snap On diagnostics tool into the OBD2 port and it did see the engine oil temp so yes the car does know it, saw it myself.
- Chris_D
If anyone can, Carly can.
She's the BESTEST!
She's the BESTEST!
Interesting. What wifi/BT adapter are you using? I have a wired Carly connector and I can only get the most basic I found with torque. Or is it a settings /config thing? Thanks MattMarius wrote: ↑Mon Apr 10, 2017 4:09 pm oil temp can be foundm inside hiden menu of the mileage display .
https://www.youtube.com/watch?v=jbuvlw3KRIk
Thank you Carly is an interesting option but I have already ordered a cheap new Android smartphone which should arrive Tuesday ready to try Torque. Fingers crossed.
i'm android user so it's bt ,using carly second gen adapterMatt64 wrote: ↑Fri Apr 14, 2017 10:19 pmInteresting. What wifi/BT adapter are you using? I have a wired Carly connector and I can only get the most basic I found with torque. Or is it a settings /config thing? Thanks MattMarius wrote: ↑Mon Apr 10, 2017 4:09 pm oil temp can be foundm inside hiden menu of the mileage display .
Thanks. I am an android user also. I did use the official torque BT odb2 dongle but it was a bit of a pia as it doesn't allow any other BT devices to be paired on the same phone. Which was a shame as I wanted some real time readings like AFR and temps.
Disaster!! No Engine Oil Temp displayed on Android phone using Torque Pro App through Bluetooth to an ELM327 OBD adapter. In the configurable list green shows the useable ones and Oil Temp is black not green
Anybody any suggestions - Marius how did you get yours to work please?
- IMG_0320.JPG (238.26 KiB) Viewed 682 times
- IMG_0319.JPG (163.59 KiB) Viewed 682 times
